Crash if you edit draft label and minimize the window
Posted: Sun Jul 31, 2022 2:31 am
- Create draft label with Custom label type.
- Edit Custom Text property
- Minimize the opened "List" editor window
- Observe that FreeCAD crashes. Stacktrace below.
#0 __GI_raise (sig=sig@entry=6) at ../sysdeps/unix/sysv/linux/raise.c:50
#1 0x00001555500bb859 in __GI_abort () at abort.c:79
#2 0x000015555012626e in __libc_message (action=action@entry=do_abort, fmt=fmt@entry=0x155550250298 "%s\n")
at ../sysdeps/posix/libc_fatal.c:155
#3 0x000015555012e2fc in malloc_printerr (str=str@entry=0x155550252670 "double free or corruption (out)") at malloc.c:5347
#4 0x000015555012ffa0 in _int_free (av=0x155550285b80 <main_arena>, p=0x7fffffffbbe0, have_lock=<optimized out>) at malloc.c:4314
#5 0x00001555548cba99 in PropertyListDialog::~PropertyListDialog() (this=0x7fffffffbbf0, __in_chrg=<optimized out>)
at ../src/Gui/Widgets.cpp:1353
#6 0x0000155550737eee in QObjectPrivate::deleteChildren() () at /lib/x86_64-linux-gnu/libQt5Core.so.5
#7 0x0000155551166c29 in QWidget::~QWidget() () at /lib/x86_64-linux-gnu/libQt5Widgets.so.5
#8 0x00001555548c1df2 in Gui::LabelEditor::~LabelEditor() (this=0x55555e090290, __in_chrg=<optimized out>)
at ../src/Gui/Widgets.cpp:1426
#9 0x00001555548c1e1c in Gui::LabelEditor::~LabelEditor() (this=0x55555e090290, __in_chrg=<optimized out>)
at ../src/Gui/Widgets.cpp:1428
#10 0x000015555073aa44 in QObject::event(QEvent*) () at /lib/x86_64-linux-gnu/libQt5Core.so.5
#11 0x000015555116b25d in QWidget::event(QEvent*) () at /lib/x86_64-linux-gnu/libQt5Widgets.so.5
#12 0x0000155551128a66 in QApplicationPrivate::notify_helper(QObject*, QEvent*) () at /lib/x86_64-linux-gnu/libQt5Widgets.so.5
#13 0x00001555511320f0 in QApplication::notify(QObject*, QEvent*) () at /lib/x86_64-linux-gnu/libQt5Widgets.so.5
#14 0x000015555427b6d0 in Gui::GUIApplication::notify(QObject*, QEvent*) (this=
0x7fffffffd160, receiver=0x55555e090290, event=0x55555e24c200) at ../src/Gui/GuiApplication.cpp:84
#15 0x000015555070e80a in QCoreApplication::notifyInternal2(QObject*, QEvent*) () at /lib/x86_64-linux-gnu/libQt5Core.so.5
#16 0x0000155550711488 in QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*) ()
#17 0x0000155550766e37 in () at /lib/x86_64-linux-gnu/libQt5Core.so.5
#18 0x000015554e3bb17d in g_main_context_dispatch () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#19 0x000015554e3bb400 in () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#20 0x000015554e3bb4a3 in g_main_context_iteration () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#21 0x0000155550766435 in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) ()
#22 0x000015555070d3ab in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () at /lib/x86_64-linux-gnu/libQt5Core.so.5
#23 0x000015555132cc6d in QDialog::exec() () at /lib/x86_64-linux-gnu/libQt5Widgets.so.5
#24 0x00001555548c2224 in Gui::LabelEditor::changeText() (this=0x55555e090290) at ../src/Gui/Widgets.cpp:1464
#25 0x00001555548c61c0 in Gui::LabelEditor::qt_static_metacall(QObject*, QMetaObject::Call, int, void**)
(_o=0x55555e090290, _c=QMetaObject::InvokeMetaMethod, _id=4, _a=0x7fffffffbdc0)
at src/Gui/FreeCADGui_autogen/include/moc_Widgets.cpp:1505
#26 0x000015555073a1d0 in QMetaObject::activate(QObject*, int, int, void**) () at /lib/x86_64-linux-gnu/libQt5Core.so.5
#27 0x000015555121d806 in QAbstractButton::clicked(bool) () at /lib/x86_64-linux-gnu/libQt5Widgets.so.5
#28 0x000015555121da2e in () at /lib/x86_64-linux-gnu/libQt5Widgets.so.5
#29 0x000015555121ee73 in () at /lib/x86_64-linux-gnu/libQt5Widgets.so.5
#30 0x000015555121f035 in QAbstractButton::mouseReleaseEvent(QMouseEvent*) () at /lib/x86_64-linux-gnu/libQt5Widgets.so.5
#31 0x000015555116b2b6 in QWidget::event(QEvent*) () at /lib/x86_64-linux-gnu/libQt5Widgets.so.5
#32 0x0000155551128a66 in QApplicationPrivate::notify_helper(QObject*, QEvent*) () at /lib/x86_64-linux-gnu/libQt5Widgets.so.5
#33 0x0000155551132343 in QApplication::notify(QObject*, QEvent*) () at /lib/x86_64-linux-gnu/libQt5Widgets.so.5
#34 0x000015555427b6d0 in Gui::GUIApplication::notify(QObject*, QEvent*)
(this=0x7fffffffd160, receiver=0x555555ddab20, event=0x7fffffffc550) at ../src/Gui/GuiApplication.cpp:84
#35 0x000015555070e80a in QCoreApplication::notifyInternal2(QObject*, QEvent*) () at /lib/x86_64-linux-gnu/libQt5Core.so.5
#36 0x0000155551131457 in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool, bool) () at /lib/x86_64-linux-gnu/libQt5Widgets.so.5
#37 0x000015555118735d in () at /lib/x86_64-linux-gnu/libQt5Widgets.so.5
#38 0x000015555118a1ec in () at /lib/x86_64-linux-gnu/libQt5Widgets.so.5
#39 0x0000155551128a66 in QApplicationPrivate::notify_helper(QObject*, QEvent*) () at /lib/x86_64-linux-gnu/libQt5Widgets.so.5
#40 0x00001555511320f0 in QApplication::notify(QObject*, QEvent*) () at /lib/x86_64-linux-gnu/libQt5Widgets.so.5
#41 0x000015555427b6d0 in Gui::GUIApplication::notify(QObject*, QEvent*)
(this=0x7fffffffd160, receiver=0x5555574b13e0, event=0x7fffffffcbf0) at ../src/Gui/GuiApplication.cpp:84
#42 0x000015555070e80a in QCoreApplication::notifyInternal2(QObject*, QEvent*) () at /lib/x86_64-linux-gnu/libQt5Core.so.5
#43 0x0000155550af97d3 in QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) ()
at /lib/x86_64-linux-gnu/libQt5Gui.so.5
#44 0x0000155550afb10b in QGuiApplicationPrivate::processWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*) ()
#45 0x0000155550ad535b in QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) ()
#46 0x000015554a16332e in () at /lib/x86_64-linux-gnu/libQt5XcbQpa.so.5
#47 0x000015554e3bb17d in g_main_context_dispatch () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#48 0x000015554e3bb400 in () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#49 0x000015554e3bb4a3 in g_main_context_iteration () at /lib/x86_64-linux-gnu/libglib-2.0.so.0
#50 0x0000155550766435 in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) ()
#51 0x000015555070d3ab in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () at /lib/x86_64-linux-gnu/libQt5Core.so.5
#52 0x0000155550715116 in QCoreApplication::exec() () at /lib/x86_64-linux-gnu/libQt5Core.so.5
#53 0x0000155554127fe2 in Gui::Application::runApplication() () at ../src/Gui/Application.cpp:2256
#54 0x0000555555566acf in main(int, char**) (argc=1, argv=0x7fffffffddf8) at ../src/Main/MainGui.cpp:285
OS: Ubuntu 20.04.4 LTS (KDE/plasma)
Version: 0.20.24436 (Git)
Build type: Debug
Hash: ecbd151b114e086ee72d6142ace5780f6220c08a
* 3DfindIT 1.2.0
* Render 2022.2.0
* BIM 2021.12.0
* Manipulator 1.4.9
* parts_library
* dodo
