Model view, DraftView, ArchView Difference - Annotation Multiplier & etc
paullee
Post by paullee »
Noted there are a number of difference :)
  1. Dimension Line on the right with an Annotation Style, Scale Multiplier set to say 50, DraftView / Archview seems not honour it
    • Dimension Line on the Right with an Annotation Style : Dot Size = 10, Scale Multiplier 50 - Dot size resulted in model view = 500
    • Dimension Line on the Left with settings Not with Annotation Style : Dot Size just set = 500
  2. Draft Line with Width set to 10, Style set to Dashed : ArchView ignore all settings; DraftView style has scale problem as discussed elsewhere
  3. Sketch with Width set to 10 : ArchView and DraftView ignore this settings
Any idea ?
Test_ Dim-Multiplier_DraftView_ArchView_01.FCStd
(36.91 KiB) Downloaded 18 times
Screenshot from 2022-07-29 15-10-36.png (216.26 KiB) Viewed 703 times
Screenshot from 2022-07-29 15-10-44.png (208.82 KiB) Viewed 703 times
Screenshot from 2022-07-29 15-13-36.png (246.48 KiB) Viewed 703 times
Roy_043
Re: Model view, DraftView, ArchView Difference - Annotation Multiplier & etc
Post by Roy_043 »
Additionally: the text height is hard-coded.
Look at:
Mod/Draft/draftfunctions/svg.py
Mod/Draft/draftfunctions/svgtext.py
paullee
Post by paullee »
Text size in DraftView / ArchView does not follow that of the original objects indeed :)
