Draft toggle grid distorts the model view
balrobs
Re: Draft toggle grid distorts the model view
Post by balrobs »
Roy_043 wrote: Sat Jun 18, 2022 1:32 pm I think I have found the cause of the issue and also the reason why not everybody was able to reproduce. It all depends on where you click the DatumPlane in the 3D view. If you click an edge the problem does not occur. If you click the face (which is an 'endless' plane) it does. So it is not related to the gridSpacing.
Wow, good catch ... confirmed!
OS: Ubuntu Core 20 (ubuntu:GNOME/ubuntu)
Version: 0.20.29182 +1 (Git) Snap 72
Branch: (HEAD detached at e4395a4bb7)
Hash: e4395a4bb7c492d1520f269ed576001bdb9389ca
Python 3.8.10, Qt 5.15.3, Coin 4.0.0, Vtk 7.1.1, OCC 7.6.2
NewJoker
Post by NewJoker »
Is it possible to solve this issue ? It also happens with the model from this thread: https://forum.freecadweb.org/viewtopic.php?f=3&t=69809
Indeed it occurs only when the face of the datum plane is selected for grid relocation. It's fine if the edge of the datum plane is selected. But still, it's a quite nasty bug since it persists until the datum plane is moved back to the origin and interferes with further operations.
Unamed1_distortion.FCStd
(29.99 KiB) Downloaded 10 times
This looks like a visual thing which can usually be fixed with the FitAll icon.
openBrain
Post by openBrain »
chrisb wrote: Mon Jun 27, 2022 8:22 am This looks like a visual thing which can usually be fixed with the FitAll icon.
You should read the OP :lol:
Roy_043
Post by Roy_043 »
openBrain wrote: Mon Jun 27, 2022 8:24 am You should read the OP :lol:
Yes :oops: .
NewJoker
Post by NewJoker »
Great, thank you very much :-)
Too bad the original problem with similar model distortion but not related to the Draft workbench can't be fixed so easily:
https://forum.freecadweb.org/viewtopic.php?f=3&t=64833
