drmacro
Posts: 8870 Joined: Sun Mar 02, 2014 4:35 pm
Post
by drmacro » Fri Jun 17, 2022 3:27 pm
thomas-neemann wrote: ↑ Fri Jun 17, 2022 3:12 pm
drmacro wrote: ↑ Fri Jun 17, 2022 3:04 pm
Confirmed on Debian
are you using an nvidia graphics card?
The machine posted is radeon.
I just tested on a machine with invidia, same result. (Though I did note the default grid was set 0.0...)
bambuko
Posts: 2165 Joined: Thu Oct 24, 2019 12:53 pm
Post
by bambuko » Fri Jun 17, 2022 3:29 pm
...are you using an nvidia graphics card?
I am using nvidia and I have no problems with it
OS: Ubuntu Core 20 (Pantheon/pantheon)
Version: 0.20.29190 (Git) Snap 68
Hash: 81be38ea8dcec49376b6ab8e08f4a85605639f8d
Python 3.8.10, Qt 5.15.3, Coin 4.0.0, Vtk 7.1.1, OCC 7.6.2
* DynamicData 2.46.0
* ToolViewReverse_ToolBar
* sheetmetal 0.2.49
* Manipulator 1.4.3
* Assembly3 0.11.3
* fasteners 0.3.40
* ThreadProfile 1.81.0
you can also download ... and try it
here
excellent Assembly3 tutorials
here
Roy_043
Posts: 8450 Joined: Thu Dec 27, 2018 12:28 pm
Post
by Roy_043 » Fri Jun 17, 2022 3:30 pm
Renaming user.cfg and restarting fixes the problem here.
Version info:
Roy_043 wrote: ↑ Fri Jun 17, 2022 12:57 pm
It seems to be related to the gridSpacing setting.
Roy_043 on Fri Jun 17, 2022 3:50 pm, edited 1 time in total.
thomas-neemann
Posts: 11801 Joined: Wed Jan 22, 2020 6:03 pm
Post
by thomas-neemann » Fri Jun 17, 2022 3:37 pm
drmacro wrote: ↑ Fri Jun 17, 2022 3:27 pm
can it be because of the kernel version? I use 5.4.0
edit
Roy_043 wrote: ↑ Fri Jun 17, 2022 3:30 pm
roy_43 has a solution
thomas-neemann on Fri Jun 17, 2022 3:43 pm, edited 2 times in total.
openBrain
Posts: 9034 Joined: Fri Nov 09, 2018 5:38 pm
Post
by openBrain » Fri Jun 17, 2022 3:39 pm
Moved to Draft.
drmacro
Post
by drmacro » Fri Jun 17, 2022 3:43 pm
Version info:
That just looses all my settings and didn't fix it here.
NewJoker
Posts: 3018 Joined: Sun Oct 11, 2020 7:49 pm
Post
by NewJoker » Fri Jun 17, 2022 6:27 pm
Thank you guys for confirming and investigating this bug. I created a GitHub report for it:
issue #7043
Roy_043
Post
by Roy_043 » Sat Jun 18, 2022 1:32 pm
I think I have found the cause of the issue and also the reason why not everybody was able to reproduce. It all depends on where you click the DatumPlane in the 3D view. If you click an edge the problem does not occur. If you click the face (which is an 'endless' plane) it does. So it is not related to the gridSpacing.
thomas-neemann
Post
by thomas-neemann » Sat Jun 18, 2022 3:06 pm
is there anything wrong with using a draft rectangle as a substitute for a datum plane?
