Draft WB - not working - new install FC 0.20
maker
Post by maker »
Hi all,
OS: openSUSE Leap 15.3 (KDE//usr/share/xsessions/default)
Version: 0.20.Unknown
Python 3.6.13, Qt 5.12.7, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
after a new installation of stable 0.20 which has been provided yesterday by openSUSE repo,
Source RPM  : FreeCAD-0.20-lp153.163.1.src.rpm
Build Date  : Mi 15 Jun 2022 19:44:26 CEST
I had the problem that draft workbench after start shows the following error messages in the report view:
00:26:31  Persistent toolbars: Snapper toolbar not managed.
00:26:31  in method 'SoAsciiText_string_set', argument 2 of type 'SoMFString *'
00:26:31  Traceback (most recent call last):
  File "<string>", line 149, in Activated
  File "/usr/lib64/FreeCAD/Mod/Draft/draftguitools/gui_snapper.py", line 1629, in show
    self.setTrackers()
  File "/usr/lib64/FreeCAD/Mod/Draft/draftguitools/gui_snapper.py", line 1673, in setTrackers
    self.grid = trackers.gridTracker()
  File "/usr/lib64/FreeCAD/Mod/Draft/draftguitools/gui_trackers.py", line 989, in __init__
    self.text1.string = " "
  File "/usr/lib64/python3.6/site-packages/pivy/coin.py", line 51919, in <lambda>
    __setattr__ = lambda self, name, value: _swig_setattr(self, SoAsciiText, name, value)
  File "/usr/lib64/python3.6/site-packages/pivy/coin.py", line 80, in _swig_setattr
    return _swig_setattr_nondynamic(self, class_type, name, value, 0)
  File "/usr/lib64/python3.6/site-packages/pivy/coin.py", line 69, in _swig_setattr_nondynamic
    return method(self, value)
00:33:35  ----------------
00:33:35  GuiCommand: Toggle grid
00:33:35  Running the Python command 'Draft_ToggleGrid' failed:
  File "/usr/lib64/FreeCAD/Mod/Draft/draftguitools/gui_grid.py", line 69, in Activated
    Gui.Snapper.setTrackers()
Has anyone any ideas, what the error cause could be?
thomas-neemann
Re: Draft WB - not working - new install FC 0.20
Post by thomas-neemann »
maker wrote: Wed Jun 15, 2022 10:36 pm ...
is it possible to download the version somewhere?
All draft functions are included in arch. does arch work?
maker
Post by maker »
thomas-neemann
maker wrote: Thu Jun 16, 2022 7:01 am ...
on xubuntu with this version
https://www.freecadweb.org/downloads.php?lang=de
it works
Version: 0.20.29177 (Git) AppImage
I wonder if it's the python version being used(v3.6).
@maker can you try the Snap to see if you can replicate the issue.
maker
Post by maker »
@Kunda1
Thankyou very much for your qualified reply.
1) I remarked also that the used python version is 3.6.
For the execution of FC is there a certain python version necessary?
2) Problem is: there is no offical snapd package provided for openSUSE Leap 15.3
The installed python versions on my OS are:
lrwxrwxrwx 1 root root     9 22. Mär 19:41 /usr/bin/python -> python2.7
lrwxrwxrwx 1 root root     9 22. Mär 19:41 /usr/bin/python2 -> python2.7
-rwxr-xr-x 1 root root  6304 22. Mär 19:41 /usr/bin/python2.7
lrwxrwxrwx 1 root root     9 16. Mär 17:17 /usr/bin/python3 -> python3.6
-rwxr-xr-x 2 root root 10584 16. Mär 17:17 /usr/bin/python3.6
lrwxrwxrwx 1 root root    17 16. Mär 17:17 /usr/bin/python3.6-config -> python3.6m-config
-rwxr-xr-x 2 root root 10584 16. Mär 17:17 /usr/bin/python3.6m
-rwxr-xr-x 1 root root  3440 16. Mär 17:17 /usr/bin/python3.6m-config
-rwxr-xr-x 1 root root  6416 23. Mär 13:19 /usr/bin/python3.9
lrwxrwxrwx 1 root root    16 16. Mär 17:17 /usr/bin/python3-config -> python3.6-config
lrwxrwxrwx 1 root root    45  9. Jun 2020  /usr/bin/pythontex -> ../share/texmf/scripts/pythontex/pythontex.py
maker
Post by maker »
@Kunda1
Try the AppImage.
Per the https://wiki.freecadweb.org/Release_not ... ompilation
Since this release FreeCAD can only be compiled using Qt 5.x and Python 3.x. The lowest supported Python version is 3.6.9 according to this forum thread.
maker
Post by maker »
@Kunda1
I tried the Appimage:
https://github.com/FreeCAD/FreeCAD-Bund ... 9.AppImage
The Draft wb works flawless.
What could be the problem of the openSUSE installation? Is it the used python version?
Is there any of the opensuse downstream maintainers you can notify about this? Not sure what the reason is honestly.
