Label display issues
mwlandolsi
Post by mwlandolsi »
Hello everybody.
Here I want to report some issues related to label display that I faced :
1- text size : the default value is very small, 0.2 mm : not readable text.
2- Text font : could not be changed
3- label type : only custom label is updated on change. For example, when choosing label type as Volume for two objects or bodies, the first can be displayed, the second, no, even when changing the text size.
4- question : how to set the units for labels : for example, volume in cm3 instead of ml.
OS: Linux Mint 20.1 (X-Cinnamon/cinnamon)
Version: 0.20.
Branch: unknown
Hash: 741fdc53c7c274aa80d1c7a0e907ab3487f5045c
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, Vtk 7.1.1, OCC 7.5.2
  * Design456 -12179872.0.0
  * Silk -12179872.0.0
  * Curves 0.4.2
  * sheetmetal 0.2.49
  * OpticsWorkbench 1.0.8
  * CurvedShapes 1.0.2
Thanks
Screenshot from 2022-06-14 07-28-02.png (47.83 KiB) Viewed 1403 times
yorik
Re: Label display issues
Post by yorik »
Cannot confirm, for me everything works fine... But it seems to me you are having the famous default coin text issue... can you check if the normal Draft text shows the same behaviour? (Unable to change text settings, and it uses a default serif, times new roman-like font).
That's the first time I see it on Linux, though. That bug usually appears on Windows. Usually it's because there is some problem between the graphic driver and the coin3D library, which is responsible for displaying the FreeCAD 3D view...
Roy_043
Post by Roy_043 »
#1: Known issue. See: https://forum.freecadweb.org/viewtopic.php?f=23&t=60483. Just set a different size in the preferences.
#2: Can't confirm, see Yorik's comment.
#3: This not completely clear, but you cannot select multiple target objects.
#4: This is currently not possible.
mwlandolsi
yorik wrote: Tue Jun 14, 2022 6:57 am can you check if the normal Draft text shows the same behaviour? (Unable to change text settings, and it uses a default serif, times new roman-like font).
Yes it is the same problem with the normal text
text.webm
(506.49 KiB) Downloaded 19 times
yorik
Post by yorik »
Okay then it is indeed our famous coin3D text bug.
What is your graphical setup? Do you have a dedicated 3D chip (nvidia, radeon)?
mwlandolsi
thans Yorik,
Can this be usefull
Screenshot from 2022-06-25 00-14-13.png (139.71 KiB) Viewed 1120 times
Screenshot from 2022-06-25 00-10-20.png (44.55 KiB) Viewed 1120 times
ragohix769
Post by ragohix769 »
yorik wrote: Tue Jun 14, 2022 6:57 am That's the first time I see it on Linux, though. That bug usually appears on Windows. Usually it's because there is some problem between the graphic driver and the coin3D library, which is responsible for displaying the FreeCAD 3D view...
I'm in Linux too, and I have the "famous" coin_text bug. This is the post in the past thread:
https://forum.freecadweb.org/viewtopic. ... 19#p597124
yorik
Post by yorik »
That's strange, I have the exact same nvidia driver in use here...
The only difference I see is that you have a Quadro chip. @ragohix769 what's your platform and graphical setup?
