(SOLVED) Grid line spacing 0 mm default in 0.20.29035
Re: (SOLVED) Grid line spacing 0 mm default in 0.20.29035
Yes that's the expected behaviour, it is reset to 1mm the first time you use a fixed version of FreeCAD. Once you have set it back, you'll be good. Later on we find a more generic way to solve these widget change issues
I encounter this issue (0 mm grid spacing) when I open the newly released stable version of 0.20. Does it mean that this PR didn't make it to the stable release ?
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Locale: Polish/Poland (pl_PL)
Is it reproductible by some way? What was the state of your 'user.cfg'? Do you see a message in the Report view?
- thomas-neemann
if I start 0.20 without configuration files everything is ok
Version: 0.20.29177 (Git) AppImage
Previously, I had 0.19 installed and I was also using the 0.20 dev version. So there might be some configuration files left.
It happened on two computers on which I installed 0.20 (each one had a previous installation of 0.19 and a dev version of 0.20).
Interestingly, on one machine I also had problems with the Sketcher grid after installing 0.20. But there the problem was the opposite - the default size was too large (1000 mm, if I recall correctly) and I wasn't able to sketch anything with snapping to grid enabled. Maybe these issues are somehow related.
Do you mean the messages that were appearing when I was trying to show the grid after installing 0.20 ? Yes, there were some that indicated the spacing is zero. When I changed it manually, they disappeared and the grid can be displayed now (also after restarting FreeCAD). However, the usual shortcut (G+R) is not working for some reason and I have to use the Toggle Draft Grid button.
