(SOLVED) I can't change the grid spacing in the weekly version
thomas-neemann
Post by thomas-neemann »
If I start the weekly version with deleted configuration files, I cannot change the grid spacing.
if I start and end once 0.19.3 it works. apparently 19.3 creates a file that is required by the weekly version and is missing.
Version: 0.20.28857 (Git) AppImage
Branch: (HEAD detached at fe4f6e0)
Hash: fe4f6e0aec3f00a5a9595bd50ba90dd866326321
edit
changing the setting has no effect
Last edited by thomas-neemann on Thu Jun 02, 2022 7:44 pm, edited 2 times in total.
thomas-neemann
Re: I can't change the grid spacing in the weekly version
workaround
if you e.g. 0.20.26720 starts you can change the settings effectively, the weekly version adopts the values, but cannot change them effectively yourself.
Roy_043
Re: (WORKAROUND) I can't change the grid spacing in the weekly version
Post by Roy_043 »
thomas-neemann
Roy_043 wrote: Sat May 14, 2022 8:18 am This PR is culprit:
https://github.com/FreeCAD/FreeCAD/pull/5427
Thank you. is the problem being worked on?
Roy_043
Post by Roy_043 »
IMO the commit should be reverted. I have added a comment to that effect:
https://github.com/FreeCAD/FreeCAD/pull ... 1126669377
thomas-neemann
Roy_043 wrote: Sat May 14, 2022 8:27 am IMO the commit should be reverted. I have added a comment to that effect:
Thanks very much
thomas-neemann
the problem is still there
Version: 0.20.28909 (Git) AppImage
Branch: (HEAD detached at 2084652)
Hash: 20846523c9d8219ec0fe33c499a64e700d2266b6
openBrain
Post by openBrain »
thomas-neemann wrote: Fri May 20, 2022 7:19 pm the problem is still there
Good news that it didn't solve by itself.
A first PR is here : https://github.com/FreeCAD/FreeCAD/pull/6899
Seems to be some more issues to solve in Draft itself where you can change grid size outside the preferences. Will look a bit later (hopefully).
thomas-neemann
openBrain wrote: Mon May 23, 2022 4:07 pm ...
thanks for the cooperation
thomas-neemann
now it works, thanks
Version: 0.20.28993 (Git) AppImage
Branch: (HEAD detached at 6d92e53)
Hash: 6d92e532bcc31c99a0ab4c153ff00b6414b8f527
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
