(SOLVED) Draft error in 28193?
- thomas-neemann
if I am in 28193 e.g. draw a 10 mm line, it is 1000 mm long. Can anybody confirm this?
(I have deleted all known configuration files)
https://www.youtube.com/watch?v=53Y331AvdTI
Version: 0.20.28193 (Git) AppImage
Branch: (HEAD detached at 9c16923)
Hash: 9c1692336740c3bc7fa0c4d430ad5ceea223384f
Python 3.9.10, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Locale: C/Default (C)
Last edited by thomas-neemann on Sat Oct 01, 2022 3:52 pm, edited 2 times in total.
Re: Draft error in 28193?
Works correctly for me but.. slightly concerned why my Locale no longer states English/United Kingdom (en_GB) as it did on Git Rev 27319
OS: Linux Mint 19.3 (X-Cinnamon/cinnamon)
Version: 0.20.27319 (Git) AppImage
Branch: (HEAD detached at 67706b1)
Hash: 67706b14df32b91b948952ea2c9350948ba4d4db
Python version: 3.9.10
Qt version: 5.12.9
OCC version: 7.5.3
* fasteners 0.3.38
* Silk 244935936.0.0
* Plot
* CfdOF 1.11.6
* BIM 2021.12.0
* FeedsAndSpeeds 0.4.0
* Curves 0.3.0
* fcgear 1.0.0
* ThreadProfile 1.81.0
* A2plus 0.4.54b
* sheetmetal 0.2.49
Qt version: 5.12.9
OCC version: 7.5.3
- ragohix769
I confirm!
Very strange indeed. To me draft creates a 10.000 m rarther then 10 mm, as in your video. It appear like if he don't understand the unit (mm => m).
OS: Ubuntu 20.04.4 LTS (KDE/plasma)
Version: 0.20.
Branch: unknown
Hash: d355b9d9e2f8365a16ed5874b35ffb8a163b19a4
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, OCC 7.5.2
* BIM
- thomas-neemann
thanks for testing
it's the same for me on windows
This is an undesirable side-effect of the new handling of the decimal separator.
https://forum.freecadweb.org/viewtopic.php?f=3&t=67344
If the FreeCAD interface language is German (or any other "comma separator language" I suppose) you can fix the problem by checking the new "Use selected language number format" preference.
See Preferences_Editor#General.
Not sure how to solve this if the interface language is English.
- thomas-neemann
Thanks for the tip, I'll test it
Nope. Locales with comma as decimal separator and period as thousand separator (AFAIK).
Maybe fix. Please test and report.you can fix the problem by checking the new "Use selected language number format" preference.
- thomas-neemann
If one having the problem is able to compile, you can test https://github.com/FreeCAD/FreeCAD/pull/6640 to see if it fixes issue.
- pathfinder
It'll work if you change the language, but I reeeeeaaaaally don't want to do this; it makes searching for solutions harder, because I first have to check for the correct English phrases.Roy_043 wrote: ↑Fri Mar 25, 2022 9:31 am This is an undesirable side-effect of the new handling of the decimal separator.
Also, if I try to check "English" and "Use selected language number format", it seems to clash with my system settings and leads to all kinds of unwanted behavior:
In Sketcher, commas get ignored.
In Path, periods get ignored, which, among other things, leads to defaults being 100.00 mm instead of 1.00 mm at first opening. And if I open the dialog again, all my settings are off again, because on top of that, commas will be automatically changed to periods.
