Issue #6613 - [Bug] Draft Snap Near is inaccurate when snapping to curves
NewJoker
Post by NewJoker »
I'm testing the Draft Snap Near option. For this purpose I created a circle and I tried to snap a line at an arbitrary angle to it. The Snap Near symbol appeared and it seems that the snap worked:
snap near 1.png (9.08 KiB) Viewed 2050 times
But when I zoom in closely, I can see some inaccuracy - the line ends not exactly on the circle but somewhere before or after it:
snap near 2.png (6.53 KiB) Viewed 2050 times
I thought that it's just a display issue since the circle is likely shown in the form of straight line segments (like in the Sketcher). But when I select that line and dimension it, the value is slightly different than the radius of the circle (the line starts from the center of the circle, I used Snap Center to ensure that). For example, it can be 37,97 mm or 37,99 mm instead of 38 mm.
All the other snaps were disabled so it can't be a problem of e.g. Snap Grid taking precedence over Snap Near.
Is that a bug or just my misunderstanding of how it's supposed to work ?
Reason: Added GH ticket number to thread title
Roy_043
Re: Draft Snap Near accuracy
Post by Roy_043 »
Confirmed. The near snap indeed snaps to the polygonal representation of the circle. There is even a slight 'magnetic' effect if you snap on a corner of the polygon. IMO this is a bug.
Note that in your zoomed-in image the line crosses the polygonal representation, I do not get that.
NewJoker
Post by NewJoker »
Roy_043 wrote: Sat Mar 19, 2022 7:51 pm Confirmed. The near snap indeed snaps to the polygonal representation of the circle. There is even a slight 'magnetic' effect if you snap on a corner of the polygon. IMO this is a bug.
Thank you for confirming this.
Could moderators move this to the Draft subforum as a potential bug report ? Or should I create a new topic there ?
Moved to Draft forum.
thomas-neemann
Post by thomas-neemann »
NewJoker wrote: Sat Mar 19, 2022 6:52 pm ... For this purpose I created a circle and I tried to snap a line at an arbitrary angle to it. ...
confirmed. here's a workaround if you want it to be precise
https://www.youtube.com/watch?v=xvPkNq7g7a0
phpBB [video]
NewJoker
Post by NewJoker »
thomas-neemann wrote: Sat Mar 19, 2022 9:01 pm confirmed. here's a workaround if you want it to be precise
Another workaround (likely the easiest one) would be to draw the line longer than it should be (so that it extends outside the circle) and then use the Draft Trimex tool on it, picking the circle as an object for the intersection. The result still seems inaccurate but that's apparently just a display issue - dimensioning shows correct value in this case.
Meanwhile, I created a bug report for that on GitHub: https://github.com/FreeCAD/FreeCAD/issues/6613
thomas-neemann
NewJoker wrote: Sat Mar 19, 2022 10:23 pm ...
Another workaround (likely the easiest one) would be to draw the line longer than it should be ....
yes, it works (very accurate for me too) but no white dot is displayed when snapping in. when i draw a second line, the white dot is shown when snapping (snap intersection)
Re: Issue #6613 - [Bug] Draft Snap Near is inaccurate when snapping to curves
Updated thread title with GH issue.
Any takers for issue #6613 ?
yorik
Post by yorik »
This is IMHO not exactly a bug - obtaining cartesian coordinates from a point on a circle inherently depends on how much precision you give to PI, which is then always imprecise, as there is no absolute value for PI. Raising the precision value in the Draft preferences makes this imprecision smaller.
There is also the fact that on screen, curves are represented faceted (OpenGL can only represent straight lines), so you might see on screen something that is not properly intersected, while in "reality", internally, it is. Raising the Deviation value of the curved objects makes the faceting smoother.
So I think this is basically unsolvable?
Roy_043
Post by Roy_043 »
I think you have misunderstood. Currently Near snap snaps to the inaccurate representation of a circle in the 3D view. No attempt is made to project the point on the actual geometry. Doing that should be possible I think, but I do not know how hard that would be. Anyway, not something that should squeezed in for V0.20 IMO.
