Arch/Bim Wall Bug?
Arch/Bim Wall Bug?
Version: 0.20.27809 (Git)
Python 3.8.12, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
* A2plus 0.4.54b
* ArchTextures
* Assembly4 0.11.10
* BIM 2021.12.0
* CADExchanger
* CubeMenu
* CurvedShapes 1.0.1
* Curves 0.3.0
* dodo
* ExplodedAssembly
* fasteners 0.3.38
* kicadStepUpMod 10.10.6
* MnesarcoUtils
* ModernUI
* Plot
* sheetmetal 0.2.49
* Trails 2022.1.0
See Bedroom 1 Wall Connections
* A2plus 0.4.54b
* ArchTextures
* Assembly4 0.11.10
* BIM 2021.12.0
* CADExchanger
* CubeMenu
* Curves 0.3.0
* dodo
* ExplodedAssembly
* fasteners 0.3.38
* MnesarcoUtils
* ModernUI
* Plot
* sheetmetal 0.2.49
* Trails 2022.1.0
- thomas-neemann
Re: Arch/Bim Wall Bug?
I think it's just a display error. it does not bother me.
I am up to Version 8 on this drawing & down graded the operating system back to FC19.3 to which I am still running into problems, Now with different areas but still an incomplete wall connection, And it does more than bother me it causes instability with Windows/Doors.
- thomas-neemann
I haven't found that yet, but I'll test it
- thomas-neemann
- thomas-neemann
the problem appears to be solved
before
after
Version: 0.20.27936 (Git) AppImage
Branch: (HEAD detached at 66f3474)
Hash: 66f34746c8e8e2b18f308d705b6a98d9d6942791
Python 3.9.10, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
T.N
Thx for the file and effort, It appears I will cont. with my intro into Arch/Bim using this method, or as you suggest ignore.
However, I do request this to be raised as a bug, WIZIWIG If your a relative new user flags will be raised if you are getting gaps in your walls. When your opening a cad package and your having trouble with this basic process, and you really shouldn't have to do things twice to get a flawless result, to me that is the definition of Bug!
- thomas-neemann
I have made the experience sketcher only as much as necessary. e.g. for tangents, oblong holes, orthogonal planes to lines, etc.
https://youtu.be/yzZUmRKfv_g
Cont Door/Window instability
Change the "Hole Depth" property of the door to f.e. 500mm.
