[PR Merged] Moving Windows/Doors
Re: Moving Windows/Doors
Ok, replaced all relevant lines.
Anyone would like to test any cornercases ?
- Screenshot from 2022-03-15 07-59-15.png (221.98 KiB) Viewed 2054 times
Do you understand the last elif in?:
https://github.com/FreeCAD/FreeCAD/blob ... #L776-L786
AFAICT only Windows have a Subvolume property. So when would the code in the elif block execute?
Thanks, that seems to work OK. Note that you will have to rebase before doing a PR as the ArchComponent.py file has seen several changes.
Attached is one of your test files with an added 'twisted' roof. The file was recomputed and saved in V0.19, so the subtractions you see when opening the file are faulty. Recomputing in V0.20 with your last ArchComponent.py file fixes this.
- Test_ Arch Door Opening_ 3_ Sketch_ Wall Offseted Roof.fcstd
- (35.28 KiB) Downloaded 46 times
There is something strange about the Roof.
Recompute make the openings of door and subtraction volume of roof correct.
Recompute the Wall again, the subtraction volume of roof seems shifted. Recompute another time, it further shift again, until there is no more subtraction
Catch-all condition which are not covered by the if / elif above ?Roy_043 wrote: ↑Tue Mar 15, 2022 12:33 pm Do you understand the last elif in?:
Confirmed.
There are two reasons for this:
- The getSubVolume function in ArchRoof.py re-uses the already generated SubVolume (self.sub), if available.
- No copy is made of the SubVolume of the roof, either in ArchRoof.py or in ArchComponent.py.
There are some interesting questions here:
Where should the copy of the SubVolume be created? I would say in ArchComponent.py. Not sure.
AFAICT the generated SubVolume of a Window is not re-used. Why is that? It might make models faster.
Thanks, would have a better look
Yes. The idea is that you could develop other kinds of embeddable objects. All they need is a Subvolume shape, which would then be recognized and used here. I have used that once to make windows with App:Parts...
That is a good idea, actually. It should be kept as a cache...
Thanks
Then, probably need a flag to identify if the 'base' Window/Roof shape had been updated so the subvolume needs updating before the latter is re-used (self.sub), right ?
