[PR Merged] Moving Windows/Doors
paullee
Re: Moving Windows/Doors
Post by paullee »
That's inspiring :)
Have no idea about shape.transformShape(), but it looks 'similar'. Can you enlighten if this change fix the OP problem and what is the difference ?
Thanks.
                        if inv_matrix:
                            add.transformShape(inv_matrix)
Roy_043
Post by Roy_043 »
paullee wrote: Sat Mar 12, 2022 3:48 pm Can you enlighten if this change fix the OP problem
As already mentioned: Yes.
paullee wrote: Sat Mar 12, 2022 3:48 pm Can you enlighten if this change fix the OP problem and what is the difference ?
In some cases a copied shape will have a Placement that is not the same as its original. Manipulations based on the Placement will then lead to faulty results. Using transformShape instead avoids this. But I have yet to check if this is the case here.
paullee
Post by paullee »
Thanks for the explanation :)
This may be same / similar problem (2018) as previously reported ?
Arch Window create Wrong Opening Position Bug?
paullee
Post by paullee »
It seems the order of inversing placement needs to take in account of the Window's placement, and below rectify the problem?
                            #subvolume.Placement = subvolume.Placement.multiply(placement)
                            subPl = FreeCAD.Placement()
                            print (" subvolume placement is ", subPl)
                            subPl = subPl.multiply(placement)  # inverse placement of Wall object
                            subPl = subPl.multiply(subvolume.Placement) # placementof Window (Opening) object
                            subvolume.Placement = subPl
ArchComponent.py
(96.71 KiB) Downloaded 48 times
DoorInsertion002_ r2.FCStd
(36.22 KiB) Downloaded 40 times
Screenshot from 2022-03-13 02-19-50.png (198.17 KiB) Viewed 2046 times
paullee
Post by paullee »
And seems it fix the problem 3 4 years ago (2018) ? :D
Before
Screenshot from 2022-03-13 02-23-47.png (186.29 KiB) Viewed 2045 times
After
Screenshot from 2022-03-13 02-24-00.png (187.57 KiB) Viewed 2045 times
paullee
Post by paullee »
Just try to compare if there is any significant difference in time, seems both 5000 routine spend about somthing slightly more than 5s.
w=Gui.Selection.getSelection()[0] # window
wl=Gui.Selection.getSelection()[0] # wall
for i in range(0,5000):
  ws=w.Proxy.getSubVolume(w)
  wlpi=FreeCAD.Placement().multiply(wl.Placement.inverse()).multiply(w.Placement)
  ws.Placement=wlpi
  inv_matrix = wl.Placement.Matrix.inverse()
  ws.transformShape(inv_matrix)
paullee
Post by paullee »
Hmmm, for some reason, the inverse_matrix method is not working ?
ArchComponent.py
(97.22 KiB) Downloaded 43 times
Test_ ArchSketch_ 49_ Window-Placement_r.FCStd
(35.63 KiB) Downloaded 41 times
Screenshot from 2022-03-14 01-56-59.png (231.03 KiB) Viewed 1880 times
Screenshot from 2022-03-14 01-57-17.png (234.07 KiB) Viewed 1880 times
Screenshot from 2022-03-14 02-18-48.png (183.63 KiB) Viewed 1880 times
Screenshot from 2022-03-14 02-19-01.png (179.13 KiB) Viewed 1880 times
Roy_043
Post by Roy_043 »
paullee wrote: Sun Mar 13, 2022 6:20 pm mmm, for some reason, the inverse_matrix method is not working ?
On line 721 you have:
placement = placement.inverse()
On line 729 you have:
inv_matrix = placement.Matrix.inverse()
In other words you are applying the inversion twice.
Roy_043
Post by Roy_043 »
paullee wrote: Sat Mar 12, 2022 6:21 pm It seems the order of inversing placement needs to take in account of the Window's placement, and below rectify the problem?
This code works.
It can be reduced to this line:
                            subvolume.Placement = placement.multiply(subvolume.Placement)
If you compare it to the original code (line 786) there is only a subtle difference:
I have to admit that I do not understand this difference.
Note that the .Placement.multiply(placement) structure occurs elsewhere in the file. I suppose it would have to be changed there as well?
paullee
Post by paullee »
Roy_043 wrote: Sun Mar 13, 2022 7:21 pm It can be reduced to this line:
Thanks. I understand the multiplication of placement is not 'commutative' in mathematics sense - so multiplication needs to be in the particular order of successive placement manipulation.
And further examining other Additions / Subtraction cases, and the bug seems exist. It can be shown that only Window object (getSubVolume) works correctly.
Test_ ArchSketch_ 49_ Window-Placement_r2.FCStd
(63.88 KiB) Downloaded 45 times
Screenshot from 2022-03-15 01-34-10.png (262.75 KiB) Viewed 1764 times
Screenshot from 2022-03-15 01-34-18.png (272.86 KiB) Viewed 1764 times
Screenshot from 2022-03-15 01-34-21.png (269.6 KiB) Viewed 1764 times
