[PR Merged] Moving Windows/Doors
yorik
Re: Moving Windows/Doors
Post by yorik »
great, i'll test too on a couple of models
paullee
Post by paullee »
Test 05 - AndrewA's model on 2021-02-19 :)
EDIT - [Solved] Door hole not in the right position
Screenshot from 2022-03-23 05-54-14.png (200.93 KiB) Viewed 1908 times
Screenshot from 2022-03-23 05-58-38.png (259.82 KiB) Viewed 1908 times
Screenshot from 2022-03-23 06-22-59.png (256.5 KiB) Viewed 1908 times
paullee
Post by paullee »
Test 06 - Fixed AndrewA's Greenhouse Roof opening with window incorrect position problem :)
EDIT - Ticket #4575 - [Solved with workaround] Window/Door holes incorrect - again
Screenshot from 2022-03-23 06-47-28.png (214.76 KiB) Viewed 1904 times
Screenshot from 2022-03-23 06-47-53.png (253.53 KiB) Viewed 1904 times
ragohix769
Post by ragohix769 »
paullee wrote: Tue Mar 22, 2022 10:24 pm Test 05 - AndrewA's model on 2021-02-19 :)
BTW: where is this Fcad project?
(I mean, where it can be downloaded)
paullee
Post by paullee »
ragohix769 wrote: Wed Mar 23, 2022 12:02 am BTW: where is this Fcad project?
Added above links to relevant discussion thread to download the model file :)
ragohix769
paullee wrote: Wed Mar 23, 2022 1:07 am
Thanks Paul!
paullee
Post by paullee »
You are welcome !
Could you also test your model files for this proposed fix, hope to prove it works on existing models and produce no regression, thanks :D
ragohix769
paullee wrote: Wed Mar 23, 2022 1:15 am You are welcome !
I'm doing already... (till now, no problem at all :-) )
paullee
Post by paullee »
Great ! Thanks !
paullee
Post by paullee »
Test 07 - @ashalper 's model
Model at Discussion Post
Screenshot from 2022-03-24 00-21-25.png (241.36 KiB) Viewed 1694 times
