Arch Frame problem/bug
Cadoss
Post by Cadoss »
Hi!
I'm having problem with Arch Frame when trying to create a beam using the Frame in 0.20.
I've created a simple example, containing a line and a profile.
The error I'm getting is the following.
19:25:22 Traceback (most recent call last):
File "/tmp/.mount_FreeCAih98zL/usr/Mod/Arch/ArchFrame.py", line 231, in execute
angle = normal.getAngle(axis)
<class 'AttributeError'>: 'NoneType' object has no attribute 'getAngle'
19:25:22 Recompute failed! Please check report view.
This started sometime during the autumn using 0.20, I can't say exactly at what version it started.
It works in 0.19.3 appimage but causing an error in the latest 0.20 appimage.
OS: Debian GNU/Linux 11 (bullseye) (MATE/lightdm-xsession)
Version: 0.20.27008 (Git) AppImage
Branch: (HEAD detached at 9162733)
Hash: 91627338a44371fe9a8e815b4900f62558af98a1
Python version: 3.9.9
Qt version: 5.12.9
OCC version: 7.5.3
Regards!
arch_frame_test_019.FCStd
(9.57 KiB) Downloaded 21 times
arch_frame_test_020.FCStd
(8.98 KiB) Downloaded 21 times
Roy_043
Re: Arch Frame problem/bug
Post by Roy_043 »
Confirmed. This commit is the cause:
https://github.com/FreeCAD/FreeCAD/comm ... c934de5eec
Will try to have a look later.
Roy_043
Post by Roy_043 »
Here is the new ArchFrame.py file for testing. The rotation behavior of the profile is more predictable than the V0.19 version. Especially for diagonal extrusion paths the rotation was hard to understand in V0.19.
frame-test.FCStd
(61.35 KiB) Downloaded 21 times
ArchFrame.py
(11.91 KiB) Downloaded 21 times
Cadoss
Post by Cadoss »
Hi!
Sorry for the delayed response!
I replaced ArchFrame.py in the appimage with yours, and it works nicely now!
Many thanks!
Roy_043
Post by Roy_043 »
Thanks for checking.
There are two other issues related to Arch_Frame that should perhaps be discussed. See: https://forum.freecadweb.org/viewtopic.php?f=23&t=65342.
thomas-neemann
Post by thomas-neemann »
the problem is still there
testfile
frame-ko.FCStd
(9.75 KiB) Downloaded 21 times
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 0.20.27319 (Git) AppImage
Branch: (HEAD detached at 67706b1)
Hash: 67706b14df32b91b948952ea2c9350948ba4d4db
Python version: 3.9.10
Qt version: 5.12.9
OCC version: 7.5.3
Roy_043
Post by Roy_043 »
I have not yet made a PR.
Roy_043
Post by Roy_043 »
thomas-neemann
Many Thanks
Roy_043
Post by Roy_043 »
The PR has meanwhile been merged.
