[BUG] crash on Arch material if two materials with the same material name are created
bernd
Post by bernd »
Just run the following code ... bang ... crash
doc = App.newDocument("MyDoc")
import Arch
matobj1 = Arch.makeMaterial("MyObjectName1")
matobj1.Material = {"Name": "MyMaterialName", "DiffuseColor": "(0.0, 1.0, 0.0, 0)"}
matobj2 = Arch.makeMaterial("MyObjectName2")
matobj2.Material = {"Name": "MyMaterialName", "DiffuseColor": "(0.0, 1.0, 1.0, 0)"}
OS: Debian GNU/Linux 10 (buster) (KDE//usr/share/xsessions/plasma)
Version: 0.20.26232 (Git)
Build type: Unknown
Hash: cd8ce95f53d4bf95d906912d8a93665b47cd592f
Python version: 3.7.3
Qt version: 5.11.3
bernd
Re: crash on Arch material if two materials with the same material name are created by Python
Post by bernd »
The crash only happens if in Preferences the following is deactivated:
General --> Document --> Allow duplicate object labels in one document
Roy_043
Post by Roy_043 »
No problem here:
OS: Windows 8.1 (6.3)
Version: 0.20.26201 (Git)
Hash: 9f2dd4a363053e87e1b1def0d005ed441d378796
Python version: 3.8.12
Qt version: 5.12.9
OCC version: 7.5.3
material-test.FCStd
(4.26 KiB) Downloaded 31 times
bernd
Post by bernd »
are you sure you deactivated the preference? See my second post.
Roy_043
Post by Roy_043 »
Yes. Just check my file. The 2nd material has not received the "MyMaterialName" name.
bernd
Post by bernd »
That is the problem why you get no crash. Did you run the Python code to create this file?
another file attached.
- open the file
- double click on MyMaterialName1
- The Arch Material task panel opens
- delete the "1" in Name ("MyMaterialName")
- click ok
- if duplicate labels are allowed in prefs it works if not crash ...
material-test_2.FCStd
(4.43 KiB) Downloaded 29 times
Roy_043
Post by Roy_043 »
bernd wrote: Thu Oct 28, 2021 10:05 am That is the problem why you get no crash. Did you run the Python code to create this file?
Yes.
bernd wrote: Thu Oct 28, 2021 10:05 am - if duplicate labels are allowed in prefs it works if not crash ...
Confirmed.
bernd
Post by bernd »
Does it mean it crashs for you with my provided file and workflow but not with the Python code?
If yes ... Strange ... Would you try the Python code once again :oops: ?
bernd
Post by bernd »
The problem is the onChanged method of the ArchMaterial.
it takes the Name from the Material dictionary and sets it to the object label, than FreeCAD changes the object label because they should not be equal, thus onChanged is called and sets again the object label. This results in an Endlesloop.
To be honest I do not like the idea to make FreeCAD reset object labels. Even if the user changes the label the label is reset. I do not know any other object ATM who does this.
bernd
Roy_043
Post by Roy_043 »
Regarding the code: I now understand the confusion.
If I run the code by pasting it in the Python console there is no problem. But running the code with Std_DlgMacroExecuteDirect does produce a crash.
