[SOLVED]Section view showing hidden stairs
robocat
Post by robocat »
Hi all,
I'm a new FreeCad user and really enjoying the freedom of the software so far, and want to say thanks to everyone involved! :D
So far I have been using BIM to create a simple model of an apartment. From this I have created a section view that has been inserted onto a page using techdraw ArchView.
The section is of a (building) containing a (floor) containing (walls, stairs, windows, doors and a floor slab).
I have unfortunately run into a quirk where the staircase that descends from a cutout in the Floor_Slab shows fully despite being partly under the Floor_Slab.
I'm still getting to grips with the software so please let me know if I have done something dumb.
Any ideas towards resolving this quirk are greatly appreciated! (Photos Below)
(Tried to attach the freecad file but says its too large)
thanks.
robocat
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
bernd
Re: Section view showing hidden stairs
Post by bernd »
It would be good to have the file.
you could make a copy of the file and delete some of the heavy objects not related to your problem. Like windows etc. With this it should be possible to get the file less than 1 MB.
robocat
Post by robocat »
Ah yes good idea!
The freecad file is attached below.
robocat
Post by robocat »
Hi all,
Has anyone been able to reproduce this issue and/or find a workaround?
To add some extra info, the sectioning issue does not seem to arise from a set of stairs under a slab in a simple mockup (see file).
From this it can maybe be determined that it is something to do with the walls in my building or the way the arch pieces have been put together?
Or maybe it's something to do with the doors and windows?
thanks
test_section.FCStd
(59.92 KiB) Downloaded 64 times
robocat
Post by robocat »
Wall, door and window seem to work fine in my test mockup... (see attechment)
I guess it must be something about the geometry I have specifically created in my file?
I'm pretty stumped :(
test_section.FCStd
(83.45 KiB) Downloaded 63 times
paullee
Post by paullee »
If a Shape2DView is made, it seem ok - except the stair which is not cut is not shown in this way.
It seem the should be hidden stair is shown overlaid on top. Seems something similar happened in earlier case ? Probably a bug.
See if @yorik has a gap to have a look.
yorik wrote: Ping
Screenshot from 2021-09-17 20-35-42.png (205.38 KiB) Viewed 3824 times
robocat
Post by robocat »
paullee wrote: Fri Sep 17, 2021 12:50 pm It seem the should be hidden stair is shown overlaid on top. Seems something similar happened in earlier case ? Probably a bug.
Yes, I agree. It seems that there is an issue with the layering when the view is created, as it puts the stairs on top of everything else.
It is interesting that the second staircase seems to section with no problems though.
Roy_043
Post by Roy_043 »
The issue is related to the stairs. "Riser Thickness" should not be zero. The same applies to "Thread Thickness". Using zero values leads to an invalid solid.
paullee
Post by paullee »
Roy_043 wrote: Sat Sep 18, 2021 10:03 am The issue is related to the stairs. "Riser Thickness" should not be zero. The same applies to "Thread Thickness". Using zero values leads to an invalid solid.
Thanks for the hint, but "Riser Thickness" and "Tread Thickness" can be zero as designed :)
But it turns out "Structure" - "One Stringer" / "Two Stringer" are broken somehow, no idea when it broke, it should worked previously. When this is set to "Massive", everything becomes normal.
So, both Stairs and ArchSection/TechDraw-ArchView has some bug :D
robocat wrote: Ping
Can you help reporting the bugs in Mantis BugTracker?
apartment_lite_ r.FCStd
(927.07 KiB) Downloaded 66 times
Screenshot from 2021-09-18 22-34-05.png (204.61 KiB) Viewed 3587 times
Screenshot from 2021-09-18 22-33-53.png (216.84 KiB) Viewed 3587 times
Screenshot from 2021-09-18 22-41-33.png (244.26 KiB) Viewed 3587 times
Roy_043
Post by Roy_043 »
paullee wrote: Sat Sep 18, 2021 2:42 pm "Riser Thickness" and "Tread Thickness" can be zero as designed
Maybe this needs to be checked. Changing the "Riser Thickness" from 0 to 1 fixes the OP's problem. And if "Riser Thickness" is zero Part_CheckGeometry does report problems. Your "Massive" solution just fixes the invalid solid issue in another way.
