Arch Wall - Block Count (Count Entire & Count Broken)
Re: Arch Wall - Block Count (Count Entire & Count Broken)
Strange. Try:
Exit FreeCAD
Delete: ...\Mod\Arch\__pycache__\ArchWall.cpython-38.pyc
Restart FreeCAD
Exit FreeCAD
Restart FreeCAD
Again: strange. It is as if a different Arch Workbench gets loaded.
You could try the following:
Add
as the first line in:
\FreeCAD_weekly-builds-29126-2022-06-12-conda-Windows-x86_64-py38\Mod\Arch\ArchWall.py
Restart FreeCAD and look for "Some message" in the Report view.
Add
print("Some message")
I added... Refer to attached images.Roy_043 wrote: ↑Tue Jun 14, 2022 9:14 pm Again: strange. It is as if a different Arch Workbench gets loaded.
Addas the first line in:Code: Select all
No Error Massages
BTW, I found something positive, give me 2 hours or more to post my finding.
Many thanks Roy
- 1.jpg (135.62 KiB) Viewed 830 times
- 2.jpg (135.37 KiB) Viewed 830 times
Palmtree wrote: ↑Thu Jun 16, 2022 3:42 amI open the original model/file… created a fresh two new walls (Wall002 & Wall003) similar/identical to original walls. Save the file as a new model (3-Brick WallR4.FCStd), By doing so, I have observed the following:
- My FC 0.20-OS: Windows 10 (refer to version below) counts the new walls bricks correctly
- My FC 0.20-OS: Windows 10 counts a wrong number of blocks for the exiting walls (Wall-Line and Wall-Line001). It is very strange. All walls blocks count was captured in the attached image).
- It seems that you have fix the issue long time ago. I was not aware, because I was testing the original file model (3-Brick WallR3.FCStd).
- Both files are attached the:
Original model/file (3-Brick WallR4.FCStd)
and
New the new model/file (3-Brick WallR4.FCStd)
- It seems your FC did not reproduce the problem
- I have no count problem running the FC realthunder (LinkDaily)
Version: 0.20.29126 (Git)
Hash: 6c1c63cffebe6a9d55bd9b1d8ca6b741a4d16548
* ArchTextures
* BIM 2021.12.0
* dodo
* Glass
* PieMenu
- Image-R2.jpg (205.05 KiB) Viewed 807 times
- 3-Brick WallR4.FCStd
- (79.68 KiB) Downloaded 12 times
- 3-Brick WallR3.FCStd
- (63.65 KiB) Downloaded 11 times
Have you tried recomputing the model? When I open your last file I also see the faulty counts, but a recompute fixes this.
From this point and later is a new issue - Similar to the former posts above and before
Hi Roy,
I observe a new issue with brick count, I hope my count is free of error!
Adopt the original model (two walls). Recompute and save as “3-Brick WallR5.FCStd”.
A copy of the file is attached.
Modify the wall model and adopt half block (0.195 m) as the “Offset First” for both walls
My count of the blocks is different from FC’s count (Short wall only, refer to attached image).
Could you please comment
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
* Behave-Dark-Colors 0.0.1
* BIM 2021.12.0
* dodo
* fasteners 0.3.44
* Glass
* PieMenu
* Reinforcement
- 3-Brick WallR5.FCStd
- (30.9 KiB) Downloaded 12 times
- 2.jpg (389.72 KiB) Viewed 711 times
Confirmed. Note that "Offset First" defines the position of the first whole block in a row and not the size of the broken block before it.
With "Offset First" set to 195 the dimensions of the blocks in the low wall are:
Offset row:
185+10+390+10+400
Non-offset row:
390+10+390+10+195
The 400mm blocks cause the count problem. Apparently if a rest dimension is equal to 2*joint or smaller the preceding block is enlarged.
Try changing "Offset First" to 205. Then the smaller blocks will all be 195 and the counts will be correct.
Offset row:
185+10+390+10+400
Non-offset row:
390+10+390+10+195
Hi Roy,
When I use the Offset First = 205 mm It works
I revise my understanding to the “Offset First - https://wiki.freecadweb.org/Arch_Wall” of blocks.
As you explained I have included an image of my revised understanding of the “Offset First", to help FC’s new users avoid misunderstand the “Offset First” similar to me.
Many Thanks you for your comments and help.
- 1.jpg (436.08 KiB) Viewed 663 times
