OS: Debian GNU/Linux bullseye/sid (XFCE/xfce)
Version: 0.19.24212 (Git) AppImage
Hash: 3d227cf7179c00e57f2733f947b4b1b0368d219a
Python version: 3.8.6
In it looks like the window (Roof001) in the Roof has cut a hole but not completed it, it was working as I had adjusted it to the size of the current hole, from smaller. I can edit Sketch007 and it changes, but the hole does not follow. I have tried things like the whole wire, changing the size of the Height of the window (Roof001) to match the Sketch007, nothing seems to work.
Also the end Windows (Window002 and Window003) are not cutting the Wall but the door is, I have lowers to make it more obvious. I suspect that this is due to the overlapping wire that produce my sills. My question, is there anyway round this? Window003 has not constrains as it lost them when I did the reflection, glad I didn't need to change the size.
I can get round both the above problems, as I have now gone for a full glass roof, I do not actually need the roof, but it does make it look a bit better. I can lower the wall for the sides and as the door works this is fine as well. Well it is fine for the 2D elevations, it looks weird in the 3d model, not idea for blender.
thanks in advance
