[Solved] Arch Space Text not visible in 3d View and overlapping in Techdraw
balrobs
Post by balrobs »
Trying to show room infos (e.g. label and area) in Techdraw results in a messed result!
Is this a bug or am I missing something?
Test_Room.FCStd
(25.63 KiB) Downloaded 35 times
Version: 0.19.23323 (Git)
Hash: 512d5c6141aec52b6eecc67370336a28fde862a6
Python version: 3.8.6
paullee
Re: [Bug?] Arch Space Text overlapping in Techdraw
Post by paullee »
balrobs wrote: Thu Dec 17, 2020 10:48 am Trying to show room infos (e.g. label and area) in Techdraw results in a messed result!
I remember there had been some bugs, see if you can help reporting in Mantis Bug Tracker, thanks :) -
  1. First, set 'First Line' and 'Font Size', say 200mmm
  2. ( wonder that should be default )
  3. Line Spacing is 1, but both line overlapping in model
  4. Set it to 2, line spacing become doubled
  5. Set it to back to 1, line spacing is ok now
Test_Room_ r.FCStd
(27.91 KiB) Downloaded 37 times
Screenshot from 2020-12-17 20-59-09.png (190.55 KiB) Viewed 1596 times
Screenshot from 2020-12-17 20-54-43.png (185.92 KiB) Viewed 1596 times
Screenshot from 2020-12-17 20-54-55.png (186.8 KiB) Viewed 1596 times
Screenshot from 2020-12-17 20-55-11.png (185.66 KiB) Viewed 1596 times
Roy_043
Post by Roy_043 »
Instead of steps 4 and 5 you can also recompute the entire model.
balrobs
Post by balrobs »
Thanks @paullee and @Roy_043,
both procedures solved my problem!
paullee
Post by paullee »
balrobs wrote: Sat Dec 19, 2020 9:59 am Ping
Can you help reporting this bug in Mantis Bug Tracker to help developer to solve it, thanks.
balrobs
Post by balrobs »
paullee wrote: Sat Dec 19, 2020 10:13 am
I will gladly do it! Will familiarize myself with the Mantis Bug Tracker System :)
paullee
Re: [Solved] Arch Space Text not visible in 3d View and overlapping in Techdraw
Post by paullee »
Thanks for reporting ! :D
Can someone test issue #6140 please?
