best way to draw 2D steel column view
- ebrahim raeyat
Hi @all, I don't know that this is related post to this topic, but my question is:
* I want to draw this steel columns in format of DXF. I take some approach, but I want to know your opinions:
1- draw section of each story and then extrude it. then use techdraw WB to obtain 2D viewing of it, then create text label for each item.
2- draw it 2D basically: use centerline of section as sketch and then offset this by Draft WB and for plates, draw it as rectangle, but this way I must calculate myself, extended line and dashed line start and end points.
3- draw without freecad: user can not modify model interactively.
Personally I prefer 1st method. Thanks
- ebrahim raeyat
Re: best way to draw 2D steel column view
I write this code for drawing section, but I want to assign all objects as Shape of Section object:
import FreeCAD
import Part
import ArchProfile
import Draft
class PartFeature:
def __init__(self, obj):
obj.Proxy = self
class Section(PartFeature):
PartFeature.__init__(self, obj)
self.set_properties(obj)
def set_properties(self, obj):
self.Type = "Section"
if not hasattr(obj, "n"):
obj.addProperty(
"App::PropertyInteger",
"n",
"section",
if not hasattr(obj, "size"):
obj.addProperty(
"size",
"section",
if not hasattr(obj, "flange_plate"):
obj.addProperty(
"App::PropertyIntegerList",
"flange_plate",
"section",
if not hasattr(obj, "web_plate"):
obj.addProperty(
"web_plate",
"section",
def execute(self, obj):
sectionType = "IPE"
sectionSize = obj.size
baseSectionType = "H"
bf = 90
d = 180
tf = 8
tw = 6
dist = 0
doc = App.ActiveDocument
group=doc.addObject("App::DocumentObjectGroup",obj.Name)
s1 = ArchProfile.makeProfile([0, sectionType, sectionType + '_000', baseSectionType ,bf, d, tw, tf])
gui = Gui.ActiveDocument
gui.getObject(s1.Label).LineColor = (1.0, 0.0, 0.0)
gui.getObject(s1.Label).DisplayMode = "Wireframe"
ipe = doc.getObjectsByLabel(s1.Label)[0]
group.addObject(s1)
deltax = bf + dist
if obj.n == 3:
Draft.move(ipe, App.Vector(deltax, 0, 0), copy=False)
s2 = Draft.move(ipe, App.Vector(-deltax, 0, 0), copy=True)
s3 = Draft.move(ipe, App.Vector(-2 * deltax, 0, 0), copy=True)
group.addObjects([s2, s3])
if obj.n == 2:
Draft.move(ipe, App.Vector(deltax / 2, 0, 0), copy=False)
s2 = Draft.rotate(ipe, 180, center=App.Vector(0, 0, 0), copy=True)
group.addObject(s2)
if obj.flange_plate:
width = obj.flange_plate[0]
height = obj.flange_plate[1]
y = d + height / 2
p3 = App.Vector(0, y, 0)
plt = ArchProfile.makeProfile([0, 'PlateT', 'PlateT' + '_000', 'R' , width, height])
gui.getObject(plt.Label).LineColor = (0.0, 0.0, 1.0)
gui.getObject(plt.Label).DisplayMode = "Wireframe"
Draft.move(doc.PlateT_000, p3)
plb = Draft.rotate(doc.PlateT_000, 180, center=App.Vector(0, 0, 0), copy=True)
group.addObjects([plt, plb])
if obj.web_plate:
width = obj.web_plate[0]
height = obj.web_plate[1]
x = ipe.Shape.BoundBox.Center.x + (ipe.WebThickness.Value + height) / 2
p6 = App.Vector(x, 0, 0)
plwr = ArchProfile.makeProfile([0, 'PlateWR', 'PlateWR' + '_000', 'R' , height, width])
gui.getObject(plwr.Label).LineColor = (0.0, 1.0, 0.0)
gui.getObject(plwr.Label).DisplayMode = "Wireframe"
Draft.move(doc.PlateWR_000, p6)
plwl = Draft.rotate(doc.PlateWR_000, 180, center=App.Vector(0, 0, 0), copy=True)
group.addObjects([plwr, plwl])
obj.Shape = Part.makeCompound([i.Shape for i in group.Group])
def decompose_section_name(name):
name = name.upper()
n = int(name[0])
size = int(name[4:6])
fi = name.find("PL")
wi = name.find("W")
if fi != -1:
if wi == -1:
flang_plate = name[fi:]
else:
flang_plate = name[fi: wi]
flang_plate = flang_plate.lstrip("PL")
flang_plate = flang_plate.split("X")
flang_plate_dim = [int(i) for i in flang_plate]
else:
flang_plate_dim = []
if wi != -1:
web_plate = name[wi:]
web_plate = web_plate.lstrip("W")
web_plate = web_plate.split("X")
web_plate_dim = [int(i) for i in web_plate]
else:
web_plate_dim = []
return(n, size, flang_plate_dim, web_plate_dim)
def make_section(name):
n, size, flange_plate, web_plate = decompose_section_name(name)
obj = FreeCAD.ActiveDocument.addObject("Part::FeaturePython", "section")
Section(obj)
obj.Label = name
obj.n = n
obj.size = size
obj.flange_plate = flange_plate
obj.web_plate = web_plate
FreeCAD.ActiveDocument.recompute()
make_section("3IPE18pl200x20w100x5")
Have you tried Dodo WB from addon manager?
- ebrahim raeyat
Thanks a lot, I had been search and find Flamingo first, but early I found that it is for python2 and skipped it. But, Dodo!! Seems good for now.
BTW, I want to do this by python script. Now, do you guys have any new suggestions?
- ebrahim raeyat
I created Section object, this is my script, Although the FreeCAD had been created profile object and I didn't understand how can I give shape of profile(with Shape.copy()?? But when I remove Profile, my shape disappear) to assign Section Object, I copy source code from Arch.makeProfile in my code, I copy create_ipe and create_plate method from Arch WB to get the shape of profile directly not profile object:
my question:
how can I use Arch.makeProfile obj and only give the shape of object only, not creating it in ActiveDocument?
import FreeCAD, FreeCADGui
import Part
from FreeCAD import Vector
import ArchProfile
from Arch import makeStructure
import Draft
import csv
from os.path import join, dirname, abspath
from columnTypeFunctions import *
class Section:
obj.Proxy = self
obj.addProperty(
"n",
"section",
obj.addProperty(
"size",
"section",
# if not hasattr(obj, "core_section"):
# obj.addProperty(
# "App::PropertyLinkList",
# "core_section",
# "Components",
# if not hasattr(obj, "flange_plate"):
# obj.addProperty(
# "flange_plate",
# "Components",
# if not hasattr(obj, "web_plate"):
# obj.addProperty(
# "web_plate",
# "Components",
if not hasattr(obj, "flange_plate_size"):
obj.addProperty(
"flange_plate_size",
"section",
if not hasattr(obj, "web_plate_size"):
obj.addProperty(
"web_plate_size",
"section",
if not hasattr(obj, "outer_wires"):
obj.addProperty(
"outer_wires",
"section",
if not hasattr(obj, "dist"):
obj.addProperty(
"App::PropertyFloat",
"dist",
"section",
if not hasattr(obj, "level"):
obj.addProperty(
"level",
"section",
name = ""
shapes = []
sectionType = "IPE"
file_name = "Section_IPE.csv"
with open(join(dirname(abspath(__file__)),"table",file_name),'r') as f:
reader=csv.DictReader(f,delimiter=';')
for row in reader:
if row['SSIZE'] == f"IPE{sectionSize * 10}":
bf = float(row["BF"])
d = float(row["D"])
tw = float(row["TW"])
tf = float(row["TF"])
break
dist = obj.dist
doc = FreeCAD.ActiveDocument
ipe = create_ipe(bf, d, tw, tf)
deltax = bf + dist
if obj.n == 3:
ipe.Placement.Base.x = deltax
ipe2 = ipe.copy()
ipe2.Placement.Base.x = 0
ipe3 = ipe.copy()
ipe3.Placement.Base.x = -deltax
# ipe2 = Draft.move(ipe, FreeCAD.Vector(-deltax, 0, 0), copy=True)
# ipe3 = Draft.move(ipe, FreeCAD.Vector(-2 * deltax, 0, 0), copy=True)
shapes.extend([ipe, ipe2, ipe3])
name += f"3{sectionType}{sectionSize}"
if obj.n == 2:
ipe.Placement.Base.x = deltax / 2
ipe2 = ipe.copy()
ipe2.Placement.Base.x = -deltax / 2
name += f"2{sectionType}{sectionSize}"
shapes.extend([ipe, ipe2])
if obj.flange_plate_size:
width = obj.flange_plate_size[0]
height = obj.flange_plate_size[1]
y = (d + height) / 2
plt = create_plate(width, height)
plt.Placement.Base.y = y
# plt.ViewObject.ShapeColor = (0.0, 0.0, 1.0)
# gui.getObject(plt.Label).DisplayMode = "Wireframe"
plb = plt.copy()
plb.Placement.Base.y = -y
# group.addObjects([plt, plb])
shapes.extend([plt, plb])
name += f"PL{width}X{height}"
if obj.web_plate_size:
width = obj.web_plate_size[0]
height = obj.web_plate_size[1]
# x = ipe.Shape.BoundBox.Center.x + (ipe.WebThickness.Value + height) / 2
x = ipe.Placement.Base.x + (tw + height) / 2
plwr = create_plate(height, width)
plwr.Placement.Base.x = x
# gui.getObject(plwr.Label).ShapeColor = (0.0, 1.0, 0.0)
# gui.getObject(plwr.Label).DisplayMode = "Wireframe"
plwl = plwr.copy()
plwl.Placement.Base.x = -x
# group.addObjects([plwr, plwl])
shapes.extend([plwr, plwl])
name += f"W{width}X{height}"
Components = Part.makeCompound(shapes)
obj.Shape = Components
obj.Placement.Base.z = obj.level
# for o in (obj.core_section + obj.flange_plate + obj.web_plate):
# hide(o)
# print(o.Label)
# FreeCAD.ActiveDocument.removeObject(o.Label)
obj.Label = name
def create_ipe(width, height, tw, tf):
import Part
p1 = Vector(-width/2,-height/2,0)
p2 = Vector(width/2,-height/2,0)
p3 = Vector(width/2,(-height/2)+tf,0)
p4 = Vector(tw/2,(-height/2)+tf,0)
p5 = Vector(tw/2,height/2-tf,0)
p6 = Vector(width/2,height/2-tf,0)
p7 = Vector(width/2,height/2,0)
p8 = Vector(-width/2,height/2,0)
p9 = Vector(-width/2,height/2-tf,0)
p10 = Vector(-tw/2,height/2-tf,0)
p11 = Vector(-tw/2,(-height/2)+tf,0)
p12 = Vector(-width/2,(-height/2)+tf,0)
p = Part.makePolygon([p1,p2,p3,p4,p5,p6,p7,p8,p9,p10,p11,p12,p1])
p = Part.Face(p)
return p
def create_plate(width, height):
import Part
p3 = Vector(width/2,height/2,0)
p4 = Vector(-width/2,height/2,0)
p = Part.makePolygon([p1,p2,p3,p4,p1])
p = Part.Face(p)
return p
# for i, section in enumerate(obj.sections):
# if i > max_index:
# return
# height = obj.levels[i+1] - obj.levels[i]
class ViewProviderSection:
"A View Provider for the Section object"
def __init__(self, vobj):
vobj.Proxy = self
def attach(self, obj):
''' Setup the scene sub-graph of the view provider, this method is mandatory '''
return
def updateData(self, fp, prop):
''' If a property of the handled feature has changed we have the chance to handle this here '''
return
def getDisplayModes(self, obj):
''' Return a list of display modes. '''
modes = []
return modes
def getDefaultDisplayMode(self):
''' Return the name of the default display mode. It must be defined in getDisplayModes. '''
return "Shaded"
def setDisplayMode(self, mode):
''' Map the display mode defined in attach with those defined in getDisplayModes.
Since they have the same names nothing needs to be done. This method is optional.
return mode
def onChanged(self, vp, prop):
''' Print the name of the property that has changed '''
FreeCAD.Console.PrintMessage("Change View property: " + str(prop) + "\n")
def make_section(name, dist=0, level=0):
# for o in FreeCAD.ActiveDocument.Objects:
# if o.Label == name.upper():
# return
n, size, flange_plate_size, web_plate_size = decompose_section_name(name)
FreeCAD.Console.PrintMessage(f"{n}, {size}, {flange_plate_size}, {web_plate_size}")
obj = FreeCAD.ActiveDocument.addObject("Part::Part2DObjectPython", "section")
Section(obj)
ViewProviderSection(obj.ViewObject)
obj.Label = name
obj.n = n
obj.size = size
obj.flange_plate_size = flange_plate_size
obj.web_plate_size = web_plate_size
obj.dist = dist
obj.level = level
return obj
if __name__ == '__main__':
make_section("3IPE18pl200x10w130x5")
make_section("3IPE18pl200x10", 0, 3000)
- ebrahim raeyat
If I want to simplify my question, I create a section object, then create an IPE object and want to assign shape of IPE to section object and remove the IPE:
If I add this line nothing change:
obj.Proxy = 0
or if I add ViewProvider() to section object.
import FreeCAD
import Arch
ipe = Arch.makeProfile([0, "IPE", "IPE", "H", 100, 200, 5, 8])
obj.Shape = ipe.Shape.copy()
obj.Proxy = 0
- ebrahim raeyat
Also, for creating Steel Column from sections, I want to assign my structures as Shape of ColumnType object:
- ebrahim raeyat
thanks, I found it from dodo WB code, it was claimChildren method of ViewProviderebrahim raeyat wrote: ↑Sat Aug 22, 2020 11:51 am Also, for creating Steel Column from sections, I want to assign my structures as Shape of ColumnType object:
- ebrahim raeyat
Hi @all. I completed code for creating columns for various type of column section in plan and elevation. Now I want to obtain 2D view from 3d column object. I want to use TechDraw WB. is there another solutions? If @"Suraj Dadral" can help. Thanks
this is my github code.
- ebrahim raeyat
I finally finished this task. This is some example of output file with ezdxf library:
with some essential hidden lines:
without hidden line:
