Thank you, @Kunda1, how can I add it?
best way to draw 2D steel column view
- ebrahim raeyat
Re: best way to draw 2D steel column view
Yorik, I'm not sure if the add-on manager would install all the needed components for this workbench.
- ebrahim raeyat
It only needs EZDXF package.
So we're going to need to tell folks to install it somehow. Or we do something else like install it via FreeCAD-pip ?
Okay I added SteelColumn to the addons! Welcome on board
About the EZDXF dependency: you can add a metadata.txt file in your repo's root dir, and inside:
(Check for example https://github.com/jmplonka/InventorLoa ... tadata.txt )
[dependencies]
pylibs=ezdxf
- ebrahim raeyat
Thanks, @yorik. I added metadata.txt file with content you said.yorik wrote: ↑Thu Dec 17, 2020 2:51 pm Okay I added SteelColumn to the addons! Welcome on board
About the EZDXF dependency: you can add a metadata.txt file in your repo's root dir, and inside:(Check for example https://github.com/jmplonka/InventorLoa ... tadata.txt )Code: Select all
[dependencies] pylibs=ezdxf
I have a very general question. Iam trying to assemble a bridge structure using std building elements such as beam, joint, rod. Also Iam in a need to show type indications suck as reactions on eccentricities and set of symbols for that.
I know there are workbenches such as BIM and dodo. Currently I am not sure if these covers my needs or if there are additional libraries fot this to add
Do you know if there are additions specifically for these type of drawings ?
Mikael
Mikael
- ebrahim raeyat
Hello @MikaelT . If I understand you correctly, you can use TechDraw WB for this.
