[Bug#4339] 019pre DraftWB, auto working plane neglect Left/Right rotation
fc_tofu
Post by fc_tofu »
Summary:
DraftWB, Menu >View >Standard view >Rotate left/right.
Or, NaviCube >Rotatate clockwise/anti-clockwise.
The roation angle is neglected when calculating automatic working plane.
Reproduce:
1. Restart FreeCAD, and switch to DraftWB.
2. Rendering mode >Flat lines.
3. At current view (Front for example), draw a closed shape (Rectangle for example).
4. Check Rectangle's Data >Base >Placement >Angle/Axis, and remember.
5. Change view with Menu >View >Standard view >Rotatate left/right. (90 degree per click).
6. Draw a closed shape (Rectangle001 for example).
7. Check Rectangle001's Data >Base >Placement >Angle/Axis, and compare with Rectangle.
8. Find 2 rectangle have same Angle/Axis data.
ps.
NaviCube >Rotatate clockwise/anti-clockwise, takes 45 degree rotation per click. It is more convinient to find this issue.
Version: 0.19.20514 (Git)
Hash: a05ffd499366ab12fa1b43f37db73f4f1e9c332d
Python version: 3.8.2
Locale: Chinese/China (zh_CN)
Tracker:
issue #4339
fc019pre_awp_neglect_left_rotate.FCStd
(5.5 KiB) Downloaded 20 times
Roy_043
Re: 019pre DraftWB, auto working plane neglect Left/Right rotation
Post by Roy_043 »
Confirmed.
OS: Windows 8.1 (6.3)
Version: 0.19.20980 (Git)
Hash: c2818d9159385d23b182dc7167af2d4bacbee94c
Python version: 3.6.8
Qt version: 5.12.1
fc_tofu
Post by fc_tofu »
Roy_043 wrote: Fri May 08, 2020 3:50 pm Confirmed.
Thanks. Posted in tracker already.
