[Bug#4341] 019pre DraftWB, shape flip on Auto WP and Bottom view
fc_tofu
Post by fc_tofu »
Summary:
DraftWB, first added shape get flipped normal orientation when Automatic working plane and Bottom view.
Reproduce:
1. Pref >Display >Part color >"Two-sided rendering" toggle off.
2. Restart FreeCAD, and switch to DraftWB.
3. Rendering mode >Flat lines.
4. Working plane >Automatic.
5. Change to Bottom view (Menu command "Bottom" or NaviCube "Bottom").
6. Create a closed shape, rectangle for example.
7. Find normal orientation of rectangle get flipped.
Workaround:
Befor step 5, change to other view (than Bottom) and draw a closed shape. Then goto step 5. Normal of created shape at Bottom view will get correct normal.
ps.
This issue doesnot happen on other views than Bottom.
Version: 0.19.20514 (Git)
Hash: a05ffd499366ab12fa1b43f37db73f4f1e9c332d
Python version: 3.8.2
Locale: Chinese/China (zh_CN)
Tracker (2020-05-14):
issue #4341
fc019pre_draftwb_first_shape_flipped_at_bottom_view.FCStd
(3.98 KiB) Downloaded 29 times
Roy_043
Re: 019pre DraftWB, shape flipped when Auto Working Plane and Bottom view
Post by Roy_043 »
Confirmed.
OS: Windows 8.1 (6.3)
Version: 0.19.20980 (Git)
Hash: c2818d9159385d23b182dc7167af2d4bacbee94c
Python version: 3.6.8
Qt version: 5.12.1
Was it like that before bottom command was changed?
fc_tofu
Post by fc_tofu »
adrianinsaval wrote: Sun May 10, 2020 1:41 pm Was it like that before bottom command was changed?
Yes, before your pr for Bottom fix. And this bug is from FC 0.18.4/Win10x64.
BTW, build with your Bottom fix can not be downloaded for now.
You must has your personal complie with the Bottom fix. So, could you please test this issue in your compile?
how do I see normal orientation? I'm not sure I understand the problem.
fc_tofu
Post by fc_tofu »
adrianinsaval wrote: Sun May 10, 2020 9:40 pm how do I see normal orientation?
Normally, such operation will create a "positive" normal face toward observers eyes. This bug produce a "negative" normal face toward observer's eyes.
In FreeCAD "Flat lines" rendering mode, "positive" normal face is rendered as grey color, and "negative" normal face is rendered as black color.
To see different normal face colors, the prerequisite is Pref >Display >Part Colors >Two-sided rendering, toggled off. (This is default setting in 0.19.)
"negative" normal face color is set in Pref >Display >3D View >Rendering >Backlight color. I changed it to dark-red on my machine, as appeared in my op.
You can compare same operation in different views to compare the normal orientations.
When composing shell/solid with surrounding faces/sufaces, flipped normal may cause erroneous geometry. It depends on the composing tool whether with normal correction capacity.
Same happens with new view bottom, it seems the working plane is not changed when you go to bottom view as it already is the XY plane, just pointing towards Z+.
vocx I have the impression you are the current Draft guru, what do you think about this?
vocx wrote:
vocx
Post by vocx »
adrianinsaval wrote: Tue May 12, 2020 3:32 pm vocx I have the impression you are the current Draft guru, what do you think about this?
Honestly, the problem could be under piles of code in the WorkingPlane module, the DraftGui module, the gui_snapper module, etc. I can't pinpoint the problem easily. I would have to dedicate many hours to find out what calls what because I don't have a clear idea of this.
I'm busy doing other things, so I don't think I will attack this problem at the moment. I appreciate the bug report, but probably Yorik would have a better idea of what needs to be changed where.
understandable
carlopav
Post by carlopav »
back to an old time proposal idea, but wouldn't it be good if the Draft Grid could be "3d", displaying also the Z axis?
