There is a tree view option called 'Sync Placement'. When enabled, it will auto adjust object's placement when drag and drop from/to group like objects, so that it does not jump. It does not work with Draft move currently. But at least it shows that it can be done.yorik wrote: ↑Mon Nov 04, 2019 6:43 pm There is another important difference, which is exactly the relative/absolute placement thing. I tried to work a bit with App::Part (it was my first idea to derive BuildingPart on App Part), and found that very disturbing that object geometry doesn't know its absolute coordinates anymore. If you move an object in/out of the App Part, either its coordinates must change, or it jumps to another place (which is what happens in App Parts). I really wanted to be able to move an object from one buildingpart to another without changing anything to its geometry or its apparent position.
BTW, @yorik, do you mind check on this issue?
