[EDIT] Latest change
- Sketch with multiple numbers of wires is supported
- And conceiving usecase of building only 1 Wall on a Sketch as layout plan
[EDIT]
Use Draft Wire to outline the series of connecting Wall with different width
Create a Wall based on the Wire
Click 'OverrideWidth' in Property Panel
Enter the figures of width for each segment following the order of Wire
Done
Other Remarks:-
You may note that it may be easier if you have the Wire alignment to either Left or Right of the Wall
- all depends on what dimensions you have for your walls
- whether building connecting walls on 1 wire is helpful depends on the layout and advance planning
The classic Width input is overridden apparently when OverrideWidth is used
When a figure in OverrideWidth is 0, the 1st figure in OverrideWidth would be used - less repeated input if possible
- if 1st figure in OverrideWdth is 0, it will fallback to use figure in Width
Using Sketch is similar, but watch the 'order' of the edge, 'connect' all edge in same direction ( as Sketcher 'construct' the Wire taking into account of edge direction )
Example Images / Files below and In Original Discussion Thread:-
Screenshot from 2019-07-14 08-42-00.png (300.77 KiB) Viewed 1916 times
Screenshot from 2019-07-14 08-42-10.png (266.67 KiB) Viewed 1916 times
. Example of model if Multiple Width is not used
Wires needs some gaps / overlapping somehow
Screenshot from 2019-07-14 08-42-45.png (292.5 KiB) Viewed 1916 times
Screenshot from 2019-07-14 08-42-55.png (272.3 KiB) Viewed 1916 times
