Arch Fence
Re: Arch Fence
@furti is not active it seems
Roy_043
Re: Arch Fence
Post by Roy_043 »
The Arch_Fence command does not create the post and section from scratch. The user has to create those objects first.
jpolonia
Re: Arch Fence
Post by jpolonia »
that is the problem, I don't know what are the initial steps to create the objects that will be part of the fence
Roy_043
Re: Arch Fence
Post by Roy_043 »
Maybe start with some Tutorials then?
jpolonia
Re: Arch Fence
Post by jpolonia »
I have searched everywhere, and there is no tutorial to make a fence, it is incredible.
could you help me with the steps?
maybe a little demo with just clicks???
furti
Re: Arch Fence
Post by furti »
@Kunda1 I'm reading the forum for a while now but unfortunately my time for amswering topics is very limited.
@jpolonia I think you struggle with the first step describes in the Arch Fence page.
The easiest way to create a post and section is to use a Part Box.
1. Switch to part workbench
2. Create part box and set length and width to 100mm and height to 1000mm. This is your post
3. Create another box. Set height and width to 100mm and length to 1000mm. move it up in z direction by 500mm. This is your section.
4. Continue with steps 2 to 5 mentioned on the Arch Fence wiki page.
Now you should have a fence.
Re: Arch Fence
@furti great to see you! Didn't know you were lurking :D
paullee
Re: Arch Fence
Post by paullee »
Furti is also the author of Arch Texture WB ! :)
jpolonia
Re: Arch Fence
Post by jpolonia »
furti wrote: Wed Nov 30, 2022 6:51 am @Kunda1 I'm reading the forum for a while now but unfortunately my time for amswering topics is very limited.
thank you very much...
