Arch Fence
engdham
Re: Arch Fence
Post by engdham »
Can a sketch profile be used for the fence post? Maybe this could become a drywall/light steel frame panel constructor:
https://cursospro.info/wp-content/uploa ... -Revit.jpg
furti
Re: Arch Fence
Post by furti »
engdham wrote: Thu May 09, 2019 12:22 am sketch profile be used for the fence post
Not with the current version. But the plan is to make this possible in the future. :)
vocx
Re: Documenting Arch Fence
Post by vocx »
furti wrote: Sun May 12, 2019 5:35 am I think @vocx updated the workbench page. Thanks for doing so :)
Two things.
I think ArchFence.py should import Part explicitly at the beginning. Otherwise you get an undefined Part error.
  File "/home/ecc/.FreeCAD/Mod/Arch/ArchFence.py", line 101, in execute
    obj, postPlacements, postLength, sectionLength)
  File "/home/ecc/.FreeCAD/Mod/Arch/ArchFence.py", line 173, in calculateSections
    sectionCopy, sectionLength, sectionLine.length() - postLength)
  File "/home/ecc/.FreeCAD/Mod/Arch/ArchFence.py", line 188, in clipSection
    leftBox = Part.makeBox(halfLengthToCut, boundBox.YMax + 1, boundBox.ZMax + 1,
<class 'NameError'>: name 'Part' is not defined
Second, I think that for consistency the user tool should be called makeFence() instead of buildFence(). Almost all commands that construct an object in FreeCAD, and in Arch, follow that pattern, makeSomething()
Also, personally, I would add default values like
def makeFence(section="simple_bars", post="rectangular", path="straight"):
Where the default values indicate simple presets, like your example at the end or in the wiki (Arch Fence).
At the end of that command, it should return the object, so the user can manipulate it further.
    return obj
furti
Post by furti »
@vocx thanks a lot for your suggestions.
vocx wrote: Mon May 13, 2019 11:35 pm I think ArchFence.py should import Part explicitly at the beginning. Otherwise you get an undefined Part error.
I fixed the missing Part Import now in the clipping method. I did not Import the Part module at the beginning, because other Arch commands do not do this either. I think this is because otherwise the Part module would be imported right when the Arch Workbench gets started, even when you do not use any of the tools inside.
vocx wrote: Mon May 13, 2019 11:35 pm Second, I think that for consistency the user tool should be called makeFence()
That is 100 percent correct. I changed the name of it.
vocx wrote: Mon May 13, 2019 11:35 pm I would add default values like
I think this can be done when a preset functionality is added to the fence. Right now there is nothing that can handle the default values.
vocx wrote: Mon May 13, 2019 11:35 pm At the end of that command, it should return the object
Shame on me that I missed that. :lol: Added the return statement now.
I created a pull request for the two fixes. https://github.com/FreeCAD/FreeCAD/pull/2173
vocx
Post by vocx »
furti wrote: Tue May 14, 2019 3:58 pm I fixed the missing Part Import now in the clipping method. I did not Import the Part module at the beginning, because other Arch commands do not do this either. I think this is because otherwise the Part module would be imported right when the Arch Workbench gets started, even when you do not use any of the tools inside.
Although I know other Arch commands import the Part module in the functions, I think this is in fact terrible. Imports in Python should be done at the top of the file. It is basically impossible to build any geometry without importing it first, so the import should happen at the top anyway.
Just like the Arch Window, you could define a makeFencePreset() function that creates a standard fence from a couple of hard coded presets.
https://github.com/FreeCAD/FreeCAD/blob ... ow.py#L120
A simple preset could be the one that you put in your example, under if __name__.
furti
Re: Arch Fence
Post by furti »
Added an option to use the Colors of the original section and fence post.
When Setting the shape Color of the fence, the whole fence is colored with the same Color
The Pull Request adds the "UseOriginalColors" Option to the Fence ViewObject.
When set to "true", the fence will inherit the Colors of the original section and post
You can simply set a Shape Color for the post and section or you can even colorize all faces of the post and section individually.
I created a Pull Request for this: https://github.com/FreeCAD/FreeCAD/pull/2263
yorik
Re: Arch Fence
Post by yorik »
Great addition! Merged.
furti
Re: Arch Fence
Post by furti »
Created another pull request that fixes some Problems with the colorization Option for the fence. https://github.com/FreeCAD/FreeCAD/pull/2270
Also uploaded some Images here of a Fence I made with the tool (https://forum.freecadweb.org/viewtopic.php?f=24&t=37121) :)
engdham
Re: Arch Fence
Post by engdham »
Would this tool allow to build something like this?
I'm thinking about an industrial plant building, with lots of handrails.
furti
Re: Arch Fence
Post by furti »
I think it should be possible to do.
I think we have to put some effort in the details like the corners and smaller sections.
Until now the sections are simply clipped when they need to be smaller than the original one.
But maybe you can give it a try and we can figure out what needs to be improved to handle this workflow.
