Arch Fence
Re: Arch Fence
I'd love to test it.
Is there any appimage or something like that with this tool enabled, or I'll have to build from source? (I have never done it )
Re: Arch Fence
If you install a 0.19 development version the fence tool should be available.
Re: Arch Fence
Re: Arch Fence
Kunda1 wrote: ↑Tue Dec 17, 2019 3:52 am @furti heads-up:
https://lgtm.com/projects/g/FreeCAD/Fre ... c3c40525:1
for i in range(8):
parts.append(Part.makeBox(20, 20, 1000 - 60,
FreeCAD.Vector((2000 / 9 * (i + 1)) - 10, 15, 30)))
This is a warning about Python 2, because in Python 2 the division operator truncates the decimal part if both quantities are integers. That is, 2000/9 = 222.LGTM wrote:Result of division may be truncated as its left and right arguments may both be integers.
In Python 3 it works as expected, 2000/9 = 222.222.
To solve this for Python 2, at least one value must be a float, 2000.0/9
See pull request #2788.
Re: Arch Fence
Thanks @vocx
You rock
You rock
Re: Arch Fence
Thanks for the quick fix I added a comment to your pull request.
For me there are two questions:
1. As python 2 is end of life and this is not a security relevant thing, should such warnings still be fixes?
2. For this actzal warning it might be better to use "from __future__ import division" because there are more divisions in the code that might fail.
Re: Arch Fence
I think adding from __future__ is ugly.
But your first point is valid: this isn't a problem in Python 3 only in Python 2. We shouldn't care any more about Python 2.
Kunda, is there a way you can set LGTM to check only Python 3 errors? This would be better.
My fix just has the intention to suppress the warning. And it's a quick fix that doesn't really impact the code, whether you use Python 2 or 3, so it's the simplest solution, I feel.
Re: Arch Fence
Did some cursory searching and wasn't successful. I'm asking for consensus and help in:
https://forum.freecadweb.org/viewtopic. ... 59#p354959
Re: Arch Fence
Hi furti, could you please help me on understanding how how to use the fence tool? Maybe it is clear but I can't see it, I create a line and afterwards, when trying to select the fence toll, I get the message "Select the section, post and path in exactly that order to build a fence", does it mean, that I have to use the Path workbench and convert the line firstly? And if so, how? Sorry, I am quite new in the use of FreeCAD and probably the question is too simple, but I find no answer in any place how to do it. Thanks in advance!
Re: Arch Fence
I am new using this program.
But I have tried to create the fence, but I can't find it.
Could you please explain the process to create one?
Thanks for your help.
JPoland.
JPoland.
