Delete objects while command is active
carlopav
Post by carlopav »
Hello, think I found a bug:
Draft.
Draw a line.
Activate a command like move.
Press "del"
The entity is deleted and the command crash.
Tried in 0.17 and my branch of 0.18. can someone reproduce it?
Could we disable the activation of other commands while one is active? I didn't get how it works now. (Would be useful also for new edit nodes tool)
Re: Delete objects while command is active
This should be already fixed. Please add your full FreeCAD infos here.
bitacovir
Post by bitacovir »
carlopav wrote: Sat Mar 09, 2019 12:30 pm
No problem here.
OS: Windows 10
Version: 0.18.16065 (Git)
Hash: 8f58abfd4961c645b3b4d7ffeea65fd551b7159b
Python version: 2.7.14
Qt version: 4.8.7
OCC version: 7.2.0
::bitacovir::
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
carlopav
Post by carlopav »
Still have it here:
Please try:
Set Draft, New Drawing, draw a line, select the line, press Move, press "DEL", the entity is deleted. the command cant complete.
RuntimeError: This object is currently not part of a document
OS: Windows 7
Version: 0.18.16079 (Git)
Hash: 6363c90a20b296ab69d7b52230009928199d90df
Python version: 3.6.6
Qt version: 5.6.2
Locale: Italian/Italy (it_IT)
bitacovir
Post by bitacovir »
I followed your indications. There is not conflict in my case.
The DEL button in the keyboard only deletes the text in the box.
Tested with the last version too.
OS: Windows 10
Qt version: 4.8.7
OCC version: 7.2.0
OS: Windows 10
Qt version: 4.8.7
OCC version: 7.2.0
::bitacovir::
carlopav
Post by carlopav »
I think i found it... can u try to set the "when drawind lines set focus on Lenght instead of X coordinate" preference, and try again to produce the error?
bitacovir
Post by bitacovir »
carlopav wrote: Sun Mar 10, 2019 2:45 pm I think i found it... can u try to set the "when drawind lines set focus on Lenght instead of X coordinate" preference, and try again to produce the error?
Yes. Now there is an error.
::bitacovir::
carlopav
Post by carlopav »
I think it is caused because the task pannel is different if you create an entity (polar input mode is present) and if you modify it (polar input mode is not present).
Think we have to uniform Draft input methods... @Yorik?
I was planning to give a look into it, but unluckly i'm tangled into work deadlines till the end of march...
carlopav opened issue #3904
carlopav
Post by carlopav »
Kunda1 wrote: Fri Mar 15, 2019 10:22 pm carlopav opened issue #3904
Thx kunda1, I forgot to post it here.
