Option between creating the walls walltrace, as sketch or as draft
Renato Rebelo
Post by Renato Rebelo »
I was wondering if it would be possible to create an option in the arch bench preferences to choose between creating the walls walltrace, as sketch or as draft.
This was important because draft lines are more flexible and easy to edit, but skecths are more powerful allowing you to use constrains. So the user could choose according to the needs.
thank you, :D
Renato Rebelo
my native language is not English, please excuse me any incorrectness, I apologize for any inconvenience caused, thank you
yorik
Re: Option between creating the walls walltrace, as sketch or as draft
Post by yorik »
That's a good idea. I think it should be not only a preference option but also a checkbox in the wall task panel so you could switch between the two anytime during your work session... Would you mind creating an issue in the tracker for it?
jaisejames
Post by jaisejames »
+1. I use draft lines for my some drawing, it was easy to change since it come with details in property editor. :)
Renato Rebelo
yorik wrote:That's a good idea. I think it should be not only a preference option but also a checkbox in the wall task panel so you could switch between the two anytime during your work session... Would you mind creating an issue in the tracker for it?
ok done
https://www.freecadweb.org/tracker/view.php?id=3001
regis
Post by regis »
Can there be some visuals about what this does? I am still clueless what is being spoken about here.
Renato Rebelo
Hello Yorik,
Do you have news about this option?
yorik
Post by yorik »
I prefer to do that after the release, as it might introduce some problems...
