Unexpected window frame/panel behaviour
hko
Post by hko »
Arch Window wiki page says "Window objects are based on closed 2D objects, such as Draft Rectangles or Sketches, that are used to define their inner components. The base 2D object must therefore contain several closed wires, that can be combined to form filled panels (one wire) or frames (several wires)."
So, I create a wall and a rectangle on the face of it:
I select the rectangle and click the window tool and a window is created. It appears that the window has a panel which is what the wiki suggests for one wire, but when I double click the window in the model tree and select the only component ("Default") for editing to see its properties, it says the type is "Frame". Why is that?
In the recent Extrude to Cut. How to get it working thread Thomas suggested to create windows and hide them in order to create openings.
Continuing my example I thought: couldn't I remove the panel to leave only the opening so that I don't have to hide the window. Well, this is what happens when I remove the "Default" component:
I have the opening in the wall but somehow the panel appears separately in the 0,0,0 coordinate now. Surely this shouldn't happen?
The final FCStd is included as an attachment.
OS: Ubuntu 20.04.4 LTS (KDE/plasma)
Version: 0.20.24436 (Git)
Build type: Debug
Hash: bf527ba5ed9cbde0813e702c2f3793fb55f5be7c
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, OCC 7.3.0
  * 3DfindIT 1.2.0
  * Render 2022.1.0
  * BIM 2021.12.0
  * Manipulator 1.4.3
  * parts_library
  * dodo
walltest.FCStd
(14.85 KiB) Downloaded 2 times
thomas-neemann
Re: Unexpected window frame/panel behaviour
Post by thomas-neemann »
hko wrote: Sat May 14, 2022 7:00 pm ..
what should the end result be?
ich biete freecad online-support an, als mini-job
youtube: https://www.youtube.com/channel/UCVcztV ... ry=freecad
paullee
Post by paullee »
hko wrote: Sat May 14, 2022 7:00 pm Arch Window wiki page says "Window objects are based on closed 2D objects, such as Draft Rectangles or Sketches, that are used to define their inner components. The base 2D object must therefore contain several closed wires, that can be combined to form filled panels (one wire) or frames (several wires)."
  1. Sketch (rather than Draft Wire/Rectangle) let you do a number of edges / wires, Sketch is default when using the Window tool, they work better together. Anyway, this is another topic / see some hint below.
    Technical Hints
  2. Just try click the Window tool without selecting anything, select the simple window type, look at the Base Sketch it autocreate, there should be a few closed Wires, which Window tool default to make them Frame, Glass Panel etc.
  3. Now if you manually create a Base (Draft Rectangle), and click Window tool, it seems to be default behaviour to use the 1st Wire as Frame, probably next few Wire as Panel etc. (or all needs manual intervention?)
  4. Frame works with 2 Wires, Window would create 2 faces, cut one from another to create a frame. Now you only have 1 Wire (Rectangle), so it is a face (panel) you got.
  5. Check the Window wiki / tutorial which teach how to create custom window type with Sketch
    Simple Workflow to create Opening
  6. I try that trick to remove all the element in Window, and hope it create opening, without any Frame, Glass Panel, but it seems Window is not customised to do this
    (Maybe someone would like to tweak the Window tool to allow this workflow ?) :D
  7. As you already have a Rectangle, just Part Extrude it, and put the Solid in the Subtraction of the Wall, and you have an opening. Cleaner this way at the moment.
walltest_ r.FCStd
(22.98 KiB) Downloaded 3 times
Screenshot from 2022-05-15 08-41-48.png (166.7 KiB) Viewed 170 times
Screenshot from 2022-05-15 08-42-50.png (202.73 KiB) Viewed 170 times
yorik
Post by yorik »
ideally, when we create a new window component automatically, if the window is based on an object containing only one wire, indeed the component type should be "Panel" and not "Frame". This is fixed in git commit 3ec140fac7
