Rational BSplines don't work
dekoning
Post by dekoning »
Hey guys,
Maybe you know it already but I'd like to report that setting the weight of Part.BSpline() to any value other than 1 doesn't work (e.g. rational BSplines don't work). Take for example the following code:
from FreeCAD import Vector
import Part
poles = [Vector(0,0),Vector(0.5,1),Vector(1,0)]
bsplinecurve = Part.BSplineCurve()
bsplinecurve.buildFromPoles(poles)
bsplinecurve.setWeight(2,0.5)
Part.show(bsplinecurve.toShape())
It gives the error:
Exception: ACCESS VIOLATION at address 0xFFFFFFFFFFFFFFFF during 'READ' operation
The use of rational Bezier curves does work as shown by the code below:
import Part
beziercurve = Part.BezierCurve()
beziercurve.setPoles(poles)
beziercurve.setWeight(2,0.5)
Part.show(beziercurve.toShape())
FYI I'm using:
OS: Windows 7
Word size: 64-bit
Version: 0.14.3700 (Git)
Branch: releases/FreeCAD-0-14
Hash: 32f5aae0a64333ec8d5d160dbc46e690510c8fe1
Python version: 2.7.6
Qt version: 4.8.5
SoQt version: 1.6.0a
OCC version: 6.6.0
shoogen
Re: Rational BSplines don't work
Post by shoogen »
I can reproduce the problem on OCCT 6.8.1-dev. It is very likely to be an upstream problem. Thanks for the report.
EDIT: not reproduce able in DRAWEXE
> bsplinecurve b2 2 2  0.0 3  1.0 3  0 0 0 1.0  0.5 1 0 0.5  1 0 0 1.0
> mkedge e1 b2 0.0 1.0
wmayer
Post by wmayer »
I can confirm the bug too. The stack trace is:
>	TKMathd.dll!TColStd_Array1OfReal::ChangeValue(const int Index=1)  Line 99 + 0x5 bytes	C++
 	TKMathd.dll!TColStd_Array1OfReal::operator()(const int Index=1)  Line 82	C++
 	TKMathd.dll!BSplCLib::BuildCache(const double U=0.00000000000000000, const double SpanDomain=1.0000000000000000, const bool Periodic=false, const int Degree=2, const TColStd_Array1OfReal & FlatKnots={...}, const TColgp_Array1OfPnt & Poles={...}, const TColStd_Array1OfReal & Weights={...}, TColgp_Array1OfPnt & CachePoles={...}, TColStd_Array1OfReal & CacheWeights={...})  Line 1074 + 0x2b bytes	C++
 	TKG3dd.dll!Geom_BSplineCurve::ValidateCache(const double Parameter=0.00000000000000000)  Line 1272	C++
 	TKG3dd.dll!Geom_BSplineCurve::D0(const double U=0.00000000000000000, gp_Pnt & P={...})  Line 121	C++
 	TKG3dd.dll!Geom_Curve::Value(const double U=0.00000000000000000)  Line 65	C++
 	TKTopAlgod.dll!BRepLib_MakeEdge::Init(const Handle_Geom_Curve & CC={...}, const TopoDS_Vertex & VV1={...}, const TopoDS_Vertex & VV2={...}, const double pp1=0.00000000000000000, const double pp2=1.0000000000000000)  Line 820 + 0x2c bytes	C++
 	TKTopAlgod.dll!BRepLib_MakeEdge::Init(const Handle_Geom_Curve & C={...}, const double p1=0.00000000000000000, const double p2=1.0000000000000000)  Line 670 + 0x3d bytes	C++
 	TKTopAlgod.dll!BRepLib_MakeEdge::BRepLib_MakeEdge(const Handle_Geom_Curve & L={...}, const double p1=0.00000000000000000, const double p2=1.0000000000000000)  Line 502 + 0x1b bytes	C++
 	TKTopAlgod.dll!BRepBuilderAPI_MakeEdge::BRepBuilderAPI_MakeEdge(const Handle_Geom_Curve & L={...}, const double p1=0.00000000000000000, const double p2=1.0000000000000000)  Line 419 + 0x76 bytes	C++
 	Part_d.pyd!Part::GeometryCurvePy::toShape(_object * args=0x0000000003137058)  Line 105 + 0x21 bytes	C++
The actual bug is inside Geom_BSplineCurve::ValidateCache.
void Geom_BSplineCurve::ValidateCache(const Standard_Real  Parameter)
  Standard_Real NewParameter ;
  Standard_Integer LocalIndex = 0 ;
  // check if the degree did not change
  if (cachepoles->Upper() < deg + 1) {                                 <<========= this check fails because cachepoles->Upper() returns "3" and "deg" is equal "2". This means "cachewieghts"
        is still a null handle but further down its method "ChangeArray1" is called
    cachepoles = new TColgp_HArray1OfPnt(1,deg + 1);
    if (rational) {
      cacheweights  = new TColStd_HArray1OfReal(1,deg + 1);
shoogen
Post by shoogen »
Thanks Werner. That explains why the curve actually needs to be changed from non-rational to rational (without increasing the degree), to reproduce the problem. I haven't found a DRAWEXE command to achieve this.
I reported it as http://tracker.dev.opencascade.org/view.php?id=25706
@dekonig:
As a workaround you can create the curve as rational right away
bsplinecurve.buildFromPolesMultsKnots(poles=(FreeCAD.Vector(0,0),FreeCAD.Vector(0.5,1),FreeCAD.Vector(1,0)),weights=(1.0,0.5,1))
wmayer
Post by wmayer »
dekoning
Post by dekoning »
Thnx guys, you are the best !
shoogen
Post by shoogen »
Yes, they are.
