rerouting output from measure linear
smktec
Post by smktec »
I would like to use the output from "measure linear". Is it possible to reroute it to a variable or spreadsheet so it can be used in python?
Roy_043
Re: rerouting output from measure linear
Post by Roy_043 »
If you mean Part_Measure_Linear, then your request does not make sense as these measurements are temporary. Try using Std_MeasureDistance or Draft_Dimension instead.
