How to check if an object has been deleted?
Re: How to check if an object has been deleted?
Another example where @chennes's delay code can solve a problem:
https://forum.freecadweb.org/viewtopic. ... 71#p657271
And another workaround...
Hilarious -- I never imagined that code being in the actual production product, I wrote it for unit testing! I'm glad it's proving useful to someone else .
Instead of using a delay it would be preferable to have a 'kill switch' for the callback of course.
Issue for the DiffuseColor bug:
https://github.com/FreeCAD/FreeCAD/issues/8340
Hello, I've tested today the code, and it is not working for PartDeseign body, or better, if you delete the PartDesign body, the subsequent objects are in the list that probably is a clone and not reflect the document changes.Roy_043 wrote: ↑Sat Jan 28, 2023 12:26 pm ...
One issue is:
if obj.TypeId in ("App::"):
This should be:
if "App::" in obj.TypeId:
But even with that mod the code makes certain assumptions that need not apply. "App::" type objects occur as subelements of PD Bodies. but not just there.
For example:Code: Select all
doc.addObject("App::DocumentObjectGroup")
So the method it trying to delete already deleted objects.
This is a doc.Object printout prior to delete <body_object>.
[<body object>, <App::Origin object>, <GeoFeature object>, <GeoFeature object>, <GeoFeature object>, <GeoFeature object>, <GeoFeature object>, <GeoFeature object>, <Sketcher::SketchObject>, <Sketcher::SketchObject>, <PartDesign::Pad>, <Sketcher::SketchObject>, <PartDesign::Pocket>, <Sketcher::SketchObject>, <PartDesign::Pad>, <PartDesign::Mirrored>, <Sketcher::SketchObject>, <PartDesign::Pocket>]
12:30:23 [<Sketcher::SketchObject>, <Sketcher::SketchObject>, <PartDesign::Pad>, <Sketcher::SketchObject>, <PartDesign::Pocket>, <Sketcher::SketchObject>, <PartDesign::Pad>, <PartDesign::Mirrored>, <Sketcher::SketchObject>, <PartDesign::Pocket>]
12:31:56 [<Sketcher::SketchObject>, <PartDesign::Pad>, <Sketcher::SketchObject>, <PartDesign::Pocket>, <Sketcher::SketchObject>, <PartDesign::Pad>, <PartDesign::Mirrored>, <Sketcher::SketchObject>, <PartDesign::Pocket>]
def clear_doc(doc_name):
"""Clear the document deleting all the objects.
Parameters:
name type description
doc_name string document name
doc = FreeCAD.getDocument(doc_name)
try:
while len(doc.Objects) > 0:
doc.removeObject(doc.Objects[0].Name)
except Exception as e:
print(f'Exception: {e}')
Thanks, doc.RootObjects may also be useful for your task.
To answer the original question:
def isDeleted(obj, doc=None):
if doc is None:
doc = App.ActiveDocument
return obj not in doc.Objects
Thanks I have to write down this check.
Another solution:
def isDeleted(obj):
return obj.FullName == "?"
