FeaturePyton. What happens when a user opens a document?
Is this sequence described somewhere?
I noticed that when opening a FeaturePython document, properties are assigned, but for some reason _init_() is not called. What then should initialize the object?
Re: FeaturePyton. What happens when a user opens a document?
If I understood correctly
When loading, all values are iterated, starting from Proxy value, and the onChanged(self, obj, prop) method is called for each itarated value.
There is a method onDocumentRestored(self, obj), but it starts after iterating through all the values.
https://wiki.freecadweb.org/FeaturePython_methods
After reading this branch as an output, is possible to check the connections between objects when the onChange method invoked.
https://forum.freecadweb.org/viewtopic.php?t=13740
It would be nice to have the OnInit() method for self-initialization. And so that this method is called before iterating over variables. Although it is possible to all without it.
You can deactivate the onChanged method during document loading with :
Then I think you can use onDocumentRestored as your an init method, called once all the properties of the object are fully restored.
def onChanged( self, fp, prop):
if "Restore" in fp.State:
return
I use construction like this:
def onChanged(self, obj, prop):
App.Console.PrintMessage("Change property: " + str(prop) + "\n")
val = obj.getPropertyByName(prop)
if prop == "ObjectData":
featureobj = self.createObjectIfItNotExists()
featureobj.data = val
I am sorry, but I lack more context and info to help further.
What I understand is that you have a FeaturePython object (obj) that creates a FeatureObject (featureobj) and transfers the data of the ObjectData property (what type of property is it ?) to it.
Without more context, this looks quite convoluted.
