[SOLVED] Cannot load module after updating to FreeCad 0.20.1
karim.achaibou
Post by karim.achaibou »
hello,
I have updated from 0.19 to version 0.020.1 and now my scripts doens'nt longer find my site-packages witch are in my virtual environment.
More specific, i want to load the "icecream" module:
(works still fine in version 0.19)
from icecream import ic
error:
  File "C:\Program Files\FreeCAD 0.20\bin\Lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import
  File "C:\Users\Achaibou Karim\AppData\Roaming\FreeCAD\Macro\fpo\tube\tube.py", line 5, in <module>
ModuleNotFoundError: No module named 'icecream'
I have also checked my user - and system variables and everything looks OK.
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
Locale: Dutch/Belgium (nl_BE)
  * dodo
  * FEM_FrontISTR
  * Manipulator 1.4.9
  * ose-piping
  * sheetmetal 0.2.59
thanks in advance.
Last edited by karim.achaibou on Sat Dec 17, 2022 8:45 am, edited 1 time in total.
Re: Cannot load module after updating to FreeCad 0.20.1
karim.achaibou wrote: Sun Dec 04, 2022 1:04 pm hello,
thanks in advance.
Each python version has his module location.
As example if FreeCAD 0.19.x will use Python 3.6.8 and FreeCAD 0.20.1 will use Python 3.8.10 if you use FreeCAD 0.20.1 and you have not installed modules for python 3.8.10 it will not find them, and it is the "correct behaviour".
So probably you have to post even "full freecad version info" for 0.19 to sort out the problem.
karim.achaibou
onekk wrote: Sun Dec 04, 2022 3:50 pm So probably you have to post even "full freecad version info" for 0.19 to sort out the problem.
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
onekk wrote: Sun Dec 04, 2022 3:50 pm As example if FreeCAD 0.19.x will use Python 3.6.8 and FreeCAD 0.20.1 will use Python 3.8.10 if you use FreeCAD 0.20.1 and you have not installed modules for python 3.8.10 it will not find them, and it is the "correct behaviour".
my installed modules (general):
C:\>pip list
Package    Version
colorama   0.4.6
executing  1.1.1
icecream   2.1.3
pip        22.3
Pygments   2.13.0
PySide2    5.15.2
PySide6    6.1.3
setuptools 56.0.0
shiboken2  5.15.2
shiboken6  6.1.3
six        1.16.0
my installed modules in my virtual environment:
C:\Users\Achaibou Karim\AppData\Roaming\FreeCAD\Macro\fpo\venv\Scripts>activate
(venv) C:\Users\Achaibou Karim\AppData\Roaming\FreeCAD\Macro\fpo\venv\Scripts>pip list
Package         Version
asttokens       2.0.8
colorama        0.4.6
et-xmlfile      1.1.0
executing       1.1.1
icecream        2.1.3
numpy           1.23.5
openpyxl        3.0.10
pandas          1.5.2
pip             21.2.4
Pygments        2.13.0
PySide2         5.15.2
python-dateutil 2.8.2
pytz            2022.6
setuptools      58.0.4
shiboken2       5.15.2
six             1.16.0
wheel           0.37.0
karim.achaibou
onekk wrote: Sun Dec 04, 2022 3:50 pm Each python version has his module location.
To install a package to a specific FreeCAD version, you have to install the package in de site-packages under bin\Lib\site-packages.
To install a package to a specific folder see link below:
https://stackoverflow.com/questions/291 ... -using-pip
For my "icecream" package it is done like below in the command prompt with administrator privileges:
C:\>pip install --target="C:\Program Files\FreeCAD 0.20\bin\Lib\site-packages" icecream
