Tangent lines to two circles
jfc4120
Post by jfc4120 »
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
  * Help 1.0.3
I needed a macro that would accomplish this. And thanks to @edwilliams16 and his reply here:
https://forum.freecadweb.org/viewtopic. ... 27#p563627
I worked it out, in his example the values are hard coded, so I tweaked it to:
from math import sqrt
# -*- coding: utf-8 -*-
import FreeCAD, FreeCADGui
import Draft
import math
# from math import cos, sin, radians
from PySide import QtGui
convert = 25.4
Placement = App.Placement
doc = App.ActiveDocument
vec = App.Vector
def tangent2C(p1, p2, rad1, rad2):
    """calculate four tangent point to join two circles
        Parameters:
        p1    Vector  Center of circle1
        p2    Vector  Center of circle2
        rad1  float   Radius of circle1
        rad2  float   Radius of circle2
        Return:
        [tg1, tg2, tg3, tg4] tangent points.
        If one circle strictly encloses the other or are they are concentric, return []
    l = (p1 - p2).Length
    if abs(rad1 - rad2) > l or l == 0:
        return []
    else:
        c = (rad1 - rad2) / l
        s = sqrt(1 - c * c)
        n = (p2 - p1) / l  # unit vector along line of centers
        m = vec(0, 0, 1).cross(n)  # orthogonal vector
        vp = c * n + s * m  # unit vectors from center to tangent points
        vm = c * n - s * m
        return [c1 + rad1 * vp, c1 + rad1 * vm, c2 + rad2 * vp, c2 + rad2 * vm]
r1 = Gui.Selection.getSelection()[0].Radius * .039370078
r2 = Gui.Selection.getSelection()[1].Radius * .039370078
r1 = float(r1)
r2 = float(r2)
selX1 = FreeCADGui.Selection.getSelectionEx()[2]
selX2 = FreeCADGui.Selection.getSelectionEx()[3]
v1 = selX1.Object.Shape
X = v1.Point.x * .039370078
Y = v1.Point.y * .039370078
Z = v1.Point.z * .039370078
multlist = [[X, Y, Z]]
v2 = selX2.Object.Shape
X = v2.Point.x * .039370078
Y = v2.Point.y * .039370078
Z = v2.Point.z * .039370078
multlist.append([X, Y, Z])
CLx = multlist[0][0]
CLy = multlist[0][1]
CSx = multlist[1][0]
CSy = multlist[1][1]
print('csx', CSx)
print('csy', CSy)
c2 = vec(CSx, CSy, 0)
c1 = vec(CLx, CLy, 0)
#c1 = vec(-35.8, 9.07, 0)
#c2 = vec(-28.3, 16.4, 0)
#r1 = 3
#r2 = 5
pto = tangent2C(c1, c2, r1, r2)
hline1 = Draft.make_line(vec(pto[1][0] * convert , pto[1][1] * convert, 0), vec(pto[3][0] * convert , pto[3][1] * convert, 0))
hline2 = Draft.make_line(vec(pto[0][0] * convert , pto[0][1] * convert, 0), vec(pto[2][0] * convert , pto[2][1] * convert, 0))
print(pto[1][0])
print(pto[1][1])
for pt in pto:
 #   print(pt[0][0])
 #   print(pt[0][1])
    print(pt)
In example images, in order select big circle then small circle then big circle center then small circle center.
Thank you @edwilliams16 for all your help. And of course tweak macro as needed. And if only one tangent is needed just delete the unwanted one.
I will do another post with tangents from an external point to a circle.
Edit:
This is in draft mode.
Roy_043
Re: Tangent lines to two circles
Post by Roy_043 »
This may be of interest:
Macro_Draft_Circle_Tangent
edwilliams16
Post by edwilliams16 »
Note that the context of my code was that the circles both lay in the XY_plane. If not:
will need to be
m = planeNormal.cross(n)
where planeNormal is the normal to the plane of the circles.
jfc4120
Post by jfc4120 »
@Roy_043 can you help with this section of Macro_Draft_Circle_Tangent:
   else:
        SINGLE = True
        circle = s1 if r1 else s2
        sx1, sx2 = Gui.Selection.getSelectionEx()
        sx = sx2 if r1 else sx1
        #point, = sx.PickedPoints         Currently in macro
        #print('point', point)
        ######## What I'm trying
        selX1 = FreeCADGui.Selection.getSelectionEx()[1]
        v9 = selX1.Object.Shape
        X = v9.Point.x
        Y = v9.Point.y
        Z = v9.Point.z
        point, = App.Vector(X, Y, Z)
With sx.PickedPoints the macro only works if the point is picked with mouse.
I'm trying to change it so I can select point from tree view. I admit I am stuck at changing the code.
I get:
File "C:/Users/Owner/AppData/Roaming/FreeCAD/Macro/Draft_Circle_Tangent_2.py", line 131, in <module>
<class 'ValueError'>: too many values to unpack (expected 1)
I am getting better, but still fairly new to Freecad Python, thanks.
Edit:
I solved it, changed the code to:
        X = v9.Point.x
        Y = v9.Point.y
        Z = v9.Point.z
        newpt = App.Vector(X, Y, Z)
        point = newpt
For some reason removing the comma (point, to point) worked. But I do appreciate all the help you have given me. :D
Edit2:
@edwilliams16 Thanks for the update, and yes my usage will be xy plane.
edwilliams16
jfc4120 wrote: Fri Nov 25, 2022 11:30 pm
else:
SINGLE = True
X = v9.Point.x
Y = v9.Point.y
Z = v9.Point.z
[/code]
sx.PickedPoints is a list. point, = sx.PickedPoints is a Python idiom for getting the first element. Others might use point = sx.PickedPoints[0]
OTOH, App.Vector(X, Y, Z) is the vector itself - no list indexing required.
Your try is very verbose
    point = selX1.Object.Shape.Point
is equivalent. No need to take the vector apart and put it back together.
jfc4120
Post by jfc4120 »
@edwilliams16
Thanks. Also concerning:
will need to be
Do you mean as example:
m = vec(0, 1, 0).cross(n)
Or is there some other code here?
edwilliams16
That's the only change. For the XY_Plane, the normal was hard-coded to App.Vector(0,0,1). Note that in the 3D case, you'll need to check (or be assured, by construction) the two circles are actually co-planar.
jfc4120
Post by jfc4120 »
@heda
Thanks for the new tangent macro :D . I recommend you change the part discussed above so a user can select a point via mouse or tree view. But pretty neat Macro. I am still working on another that has a tangent line from a point to circle. I know yours already does as well, but it's just for fun. I have enjoyed programming stuff in python.
heda
Post by heda »
Screenshot from 2022-12-04 13-38-00.png (12.02 KiB) Viewed 604 times
"I have enjoyed programming stuff in python."
welcome to a growing crowd :-)
jfc4120
Post by jfc4120 »
@heda thanks for the fix, now a point or line end works perfect.
I have programmed many sheet metal duct fitting in the past in "basiccad". And I am enjoying now programming many of them in python. One of the latest is a rectangular ogee offset.
