Linked Objects to an Array
keithsloan52
Post by keithsloan52 »
I have a macro that is processing a series of linked Objects and would like to replace with an Array.
Printing out the objects and their placements I have
20:16:47  Process Volume VeloRFBoxlvRFFrBx2
20:16:47  Array Num 4
20:16:47  VeloRFBoxlvRFFrBx2 Placement [Pos=(-23,0,772.38), Yaw-Pitch-Roll=(0,-90,360)]
20:16:47  VeloRFBoxlvRFFrBx2_001 Placement [Pos=(-23,0,-319.9), Yaw-Pitch-Roll=(0,-90,360)]
20:16:47  VeloRFBoxlvRFFrBx2_002 Placement [Pos=(23,-2.8e-15,772.38), Yaw-Pitch-Roll=(0,-90,180)]
20:16:47  VeloRFBoxlvRFFrBx2_003 Placement [Pos=(23,-2.8e-15,-319.9), Yaw-Pitch-Roll=(0,-90,180)]
Would this be a circular array and if so what would it parameters be?
Or is it a square array
Roy_043
Re: Linked Objects to an Array
Post by Roy_043 »
Instead of circular you probably mean polar array. The rotation of the objects suggests a symmetry that cannot be achieved with either array types. Creating an array from a link by changing its "Element Count" property is perhaps an option? You can then basically control the placement of each individual element.
keithsloan52
On second thoughts maybe it is not polar, would I be correct that this could be replaced by an orthogonal array 2 x 1 x 2
with x interval of 46 and z interval of 1082.28 initial Placement -23, 0, 772.38
How does Roll changing from 360 to 180 effect things?
