[Solved] Get arc angle and radius
jfc4120
Post by jfc4120 »
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
  * Help 1.0.3
Image attached which explains. I Googled this but nothing comes up, I used terms like:
freecad python get arc angle
freecad python get last angle of arc
I am trying to get angle and radius.
I know I can multiple .0174533 x r x degree, but here it's unknown.
There has got to be a way. Also is there some documentation elsewhere which covers this, I didn't see it in the regular documentation?
Believe I searched, you would think a Google search would bring this up.
heda
Re: Get arc angle and radius
Post by heda »
have you tried
App.ActiveDocument.Arc005.LastAngle
jfc4120
Post by jfc4120 »
I won't know the name of the arc in python, I need to get angle and radius from selection.
Edit:
I got radius:
RAD = Gui.Selection.getSelectionEx()[0].SubObjects[0].Curve.Radius * .039370078
print(RAD)
Haven't figured out angle yet, I tried several things.
It depends.
For a generic shape there could be or could be not an angle and radius.
In the specific case you have a Draft object that has some Properties tha usually you could access from Python.
The most easy way to know "property name" is to change it with GUI and see what is echoed in Python Console.
Hope it help.
jfc4120
Post by jfc4120 »
I do not understand. But it will be an arc.
Edit:
Where is all of the documentation that covers all of the possibilities of:
Gui.Selection.getSelectionEx()[0].SubObjects[0]?
I cannot find it anywhere.
jfc4120 wrote: Tue Oct 04, 2022 11:48 pm ...
What documentation you intend?
Python is object oriented, so:
Is simply returning a DocumentObject you selected (the first as it is a list and you are retrieving first element using [0]).
.SubObjects[0]
is returning first subobject and so on.
It is basic Python.
heda
Post by heda »
well, a bit salty, so I will go a bit salty as well...
you have been here for a while now and there are plenty of posts of yours showing that you know how to get hold of a selected object.
when writing the earlier post i decided against putting in the phrase "if you want to make it complicated for yourself you can find that through the objects shape/curve", which it now turns out is the route you took (not overly surprising, but there is an easier route given in my first post, which you clearly did not even explore, but just threw in the garbage over something that you yourself already know).
one can search the web for "fixed vs growth mindset" and think a minute or two in which category one falls into (and what that generally means for learning things)...
the correct search term is "freecad properties", the two top links are correct hits in my search engine, although the 2nd one is the most informative - they are both freecad wiki pages...
a suggestion is to study some (any) basic python write-up on object oriented programming, as a self-taught hobby coder (speaking about myself) it took quite a while before the penny finally dropped when it comes to objects in python, but when it did, anything code related became a heck of a lot easier to make the computer to do what one wanted (and also easier to absorb documentation).
so considering a fact of life, python objects...
App.ActiveDocument.Arc005.LastAngle is exactly the same (yes, literally exactly the same, not similar) as Gui.Selection.getSelectionEx()[0].LastAngle
assuming that you have selected Arc005, or - you could as well have asked the question "how do I get an object property", selection has little to do with it, since you already know how to get an object from a selection...
try it yourself...
docobj1 = App.ActiveDocument.Arc005
docobj2 = Gui.Selection.getSelectionEx()[0]
assert docobj1.LastAngle == docobj2.LastAngle
docobj1 is docobj2
how to get the radius in an analogue way I leave up to you to find out when you now have the path of how to get the last angle (that is presented in the property editor for a draft arc)...
going the route you have been shown (but for reasons beyond my comprehension discard) is the easy way.
anyhow, to get what you want in your own words...
Gui.Selection.getSelectionEx()[0].LastParameter*180/pi
btw, are you always going to assume that the starting angle is zero?
jfc4120
Post by jfc4120 »
I tried:
LA = Gui.Selection.getSelectionEx()[0].SubObjects[0].LastAngle
print(LA)
and
LA = Gui.Selection.getSelectionEx()[0].LastAngle
print(LA)
and
LA = Gui.Selection.getSelectionEx()[0].SubObjects[0].Curve.LastAngle
print(LA)
And I get:
<class 'AttributeError'>: 'Part.Edge' object has no attribute 'LastAngle'
The object has no attribute 'LastAngle' in all attempts.
This:
LA = App.ActiveDocument.Arc005.LastAngle
Does work, but is of no use hard coding a named arc.
What if i click Arc002? But I have Arc005 hard coded, then what.
Edit:
You get radius via:
Logic would tell you that LastAngle should be:
But that is not the case. Well I cannot even enter Arc005, when I try:
VAR = input("Arc Name:")
LA = App.ActiveDocument.VAR.LastAngle
You cannot use a variable there. So it seems that to use python to achieve this, I have to only select an arc with a name of Arc005.
If I have to choose Arc004, I will have to modify the program and hard code in Arc004.
Is there a solution?
Roy_043
Post by Roy_043 »
Gui.Selection.getSelectionEx()[0].SubObjects[0].LastParameter
Parameter in radians.
heda
Post by heda »
one has to keep track of which objects one has at hand...
(also valid for me :-))
LastAngle is a property of the document object (App.ActiveDocument.Arc), not the shape curve (App.ActiveDocument.Arc.Shape.Curve) (see long script at end)
so, the below will work
Gui.Selection.getSelection()[0].LastAngle
probably other selection scheme constructs works as well, but if you want to get hold of LastAngle, it is the document object that is needed (if you want it directly, can of course also go via Curve, but it is more elaborate).
sure, one can pick up any attribute dynamically (anytime, anywhere), sample constructs are...
LA = getattr(App.ActiveDocument, VAR).LastAngle
# with vanilla python, and
LA = App.ActiveDocument.getObject(VAR).LastAngle
# using getobject from fc...
## exploring objects
<Part::Part2DObject>
>>> App.ActiveDocument.Arc.LastAngle
116.56504903391658 deg
# selecting the arc in tree-view
[<Part::Part2DObject>]
<SelectionObject>
>>> Gui.Selection.getSelectionEx()[0].Object
# selecting the arc in 3d-view
(<Edge object at 0x55f0ede455b0>,)
<Edge object at 0x55f0f6b6fd40>
Circle (Radius : 19.7996, Position : (-7.50708, 6.65722, 0), Direction : (0, 0, 1))
>>> Gui.Selection.getSelectionEx()[0].Object is App.ActiveDocument.Arc
True
>>> Gui.Selection.getSelectionEx()[0].SubObjects[0] is App.ActiveDocument.Arc
False
>>> Gui.Selection.getSelectionEx()[0].SubObjects[0] is App.ActiveDocument.Arc.Shape
False ## hm...
<Edge object at 0x7f8880022b70>
<Edge object at 0x7f88800151e0>
<Edge object at 0x7f88800226c0>
<Edge object at 0x7f88800166d0>
# so new objects and thus id's are created every time called...
# so a different route is needed to check if they contain the same..
# for simplicity, check content...
>>> Gui.Selection.getSelectionEx()[0].SubObjects[0].Curve.Content
'<GeoExtensions count="0">\n</GeoExtensions>\n<Circle CenterX="-7.50708" CenterY="6.65722" CenterZ="0" NormalX="0" NormalY="0" NormalZ="1" AngleXU="-0" Radius="19.7996"/>\n'
>>> App.ActiveDocument.Arc.Shape.Curve.Content
# well, at least same content...
>>> dir(Gui.Selection.getSelectionEx()[0].SubObjects[0].Curve)
['AngleXU', 'Axis', 'Center', 'Content', 'Continuity', 'Eccentricity', 'FirstParameter', 'LastParameter', 'Location', 'MemSize', 'Module', 'Radius', 'Rotation', 'Tag', 'TypeId', 'XAxis', 'YAxis', '__class__', '__delattr__', '__dir__', '__doc__', '__eq__', '__format__', '__ge__', '__getattribute__', '__gt__', '__hash__', '__init__', '__init_subclass__', '__le__', '__lt__', '__ne__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', 'approximateBSpline', 'centerOfCurvature', 'clone', 'continuityWith', 'copy', 'curvature', 'deleteExtensionOfName', 'deleteExtensionOfType', 'discretize', 'dumpContent', 'getAllDerivedFrom', 'getD0', 'getD1', 'getD2', 'getD3', 'getDN', 'getExtensionOfName', 'getExtensionOfType', 'getExtensions', 'hasExtensionOfName', 'hasExtensionOfType', 'intersect', 'intersect2d', 'intersectCC', 'intersectCS', 'isClosed', 'isDerivedFrom', 'isPeriodic', 'length', 'makeRuledSurface', 'mirror', 'normal', 'parameter', 'parameterAtDistance', 'period', 'restoreContent', 'reverse', 'reversedParameter', 'rotate', 'scale', 'setExtension', 'tangent', 'toBSpline', 'toNurbs', 'toShape', 'transform', 'translate', 'trim', 'value']
>>> 'LastAngle' in dir(Gui.Selection.getSelectionEx()[0].SubObjects[0].Curve)
False
>>> dir(App.ActiveDocument.Arc)
['Area', 'Attacher', 'AttacherType', 'AttachmentOffset', 'Content', 'Document', 'ExpressionEngine', 'FirstAngle', 'FullName', 'ID', 'InList', 'InListRecursive', 'Label', 'Label2', 'LastAngle', 'MakeFace', 'MapMode', 'MapPathParameter', 'MapReversed', 'MemSize', 'Module', 'MustExecute', 'Name', 'NoTouch', 'OldLabel', 'OutList', 'OutListRecursive', 'Parents', 'Placement', 'PropertiesList', 'Proxy', 'Radius', 'Removing', 'Shape', 'State', 'Support', 'TypeId', 'ViewObject', 'Visibility', '__class__', '__delattr__', '__dir__', '__doc__', '__eq__', '__format__', '__ge__', '__getattribute__', '__gt__', '__hash__', '__init__', '__init_subclass__', '__le__', '__lt__', '__ne__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', 'addExtension', 'addProperty', 'adjustRelativeLinks', 'changeAttacherType', 'clearExpression', 'dumpContent', 'dumpPropertyContent', 'enforceRecompute', 'evalExpression', 'getAllDerivedFrom', 'getDocumentationOfProperty', 'getEditorMode', 'getEnumerationsOfProperty', 'getGlobalPlacement', 'getGroupOfProperty', 'getLinkedObject', 'getParentGeoFeatureGroup', 'getParentGroup', 'getPaths', 'getPathsByOutList', 'getPropertyByName', 'getPropertyNameOfGeometry', 'getPropertyOfGeometry', 'getPropertyStatus', 'getPropertyTouchList', 'getStatusString', 'getSubObject', 'getSubObjectList', 'getSubObjects', 'getTypeIdOfProperty', 'getTypeOfProperty', 'hasChildElement', 'hasExtension', 'isDerivedFrom', 'isElementVisible', 'isValid', 'positionBySupport', 'purgeTouched', 'recompute', 'removeProperty', 'resolve', 'resolveSubElement', 'restoreContent', 'restorePropertyContent', 'setDocumentationOfProperty', 'setEditorMode', 'setElementVisible', 'setExpression', 'setGroupOfProperty', 'setPropertyStatus', 'supportedProperties', 'touch']
>>> 'LastAngle' in dir(App.ActiveDocument.Arc)
True
