Comparing placements using "isEqual" sets Touched, Bug??
freedman
Post by freedman »
First, I presume the phrase Dynamic data is the same as added property.
In a macro I do many compares using "isEqual" and "isSame" to dynamic data. As a test, if I compare a Placement to itself using local data then all is fine but if I compare a placement to Dynamic data then Touched is set. For this post I don't care about the compare out-come, I have issues with Touched. This seems broken, doing a compare should not change the state of the model. Here is a test macro.
tolerance = .0001
print(" First test --------------", App.activeDocument().isTouched())
for obj in App.activeDocument().Objects:
    if obj.TypeId == "Sketcher::SketchObject":
        if not hasattr(obj,"Copy_placement"):  # add property
            obj.addProperty("App::PropertyPlacement","Copy_placement")
            obj.Copy_placement = obj.Placement     # copy the placement
        print("Found sketch")
        print( App.activeDocument().isTouched())
#        if obj.Placement.Base.isEqual(obj.Copy_placement.Base, tolerance):
#            None
You need to create a minimal model with a sketch. If you run the macro as is, Touched will stay False but if you uncomment the isEqual script and run it Touched will be set True. I don't know why this occurs.
Thanks
Re: Comparing placements using "isEqual" sets Touched, Bug??
freedman wrote: Sun Oct 02, 2022 4:01 pm ...
It is not the commented lines that cause the problem.
Problem is different, try this code:
tolerance = .0001
            obj.recompute()
#            None
you have modified the object with:
But the recompute has not been properly triggered, so you are comparing an "old state" so the False printed.
In my code I have correctly issued the object recomputing when you add Copy_placement property "et voila" the test is showing True, with the "offending" code left commented out.
freedman
Post by freedman »
onekk,
This runs the first pass only to init the new property. Run the macro multiple times afterwards to see the error.
obj.recompute()
This situation is not good for what I'm trying to do, it means that every time I compare a placement (to dynamic data) I will need to do a recompute to clear Touched.
I see this in 0.20 and 0.21. Maybe this should be in the "Help section".
EDIT: I'm trying to shorten things, to not crowd the post with not useful things.
Roy_043
Post by Roy_043 »
Seems like a bug to me. One way to workaround this (in this case):
App.Vector(obj.Placement.Base).isEqual(obj.Copy_placement.Base, tolerance)
freedman
Post by freedman »
Tested!
if App.Vector(obj.Placement.Base).isEqual(obj.Copy_placement.Base, tolerance):
That works! This runs and Touched stays False as it should in this case.
Edit: For the rotation use: App.Rotation
Reading data certainly shouldn't affect the model status so I will write this up as a bug. I won't question the difference in coding but I will do testing, I hope this new script will run faster.
Thanks Roy_043
EDIT: This post was not adding significative things as solution is found and has proven to be a bug.
Roy_043
Post by Roy_043 »
FreeCAD.Placement.Base
Is not the same as:
FreeCAD.Placement().Base
openBrain
Post by openBrain »
https://github.com/FreeCAD/FreeCAD/pull/7559
@freedman Thanks for reporting.
openBrain
Post by openBrain »
Merged
