[solved] Sketch vs Extrude - how sketch is working?
dprojects
Post by dprojects »
I am trying to create wood part from vertices. The extrude command "pad" object always along axis, so the edges may not be 90 degree if the object is rotated, I mean if the vertices are not at the same axis. So, and this will be the most funny part, I decided to create face and then ;-) create Sketch at that face and pad it from that face ;-)
But there is small problem with the Sketch ;-) The face is created correctly but if I use the face as "DatumPlane", Support, for Sketch this has placement offset at XY. But if I want to create the Sketch at the side the face is correct but the Sketch with the same vertices is broken.
I know there is different logic with attachment of the Sketch but the question is? Is it possible? is there any logic or formula to recalculate object vertices to "Sketch vertices" ? to create Sketch exactly as the real object? to cover all edges with Sketch lines?
Thanks
Darek
github.com/dprojects
Re: Sketch vs Extrude - how sketch is working?
dprojects wrote: Fri Sep 30, 2022 4:04 pm ... The extrude command "pad" object always along axis...
It is not true, you could extrude along some combination of axis, see maybe:
20220930-sketch_pad.py
(4.2 KiB) Downloaded 18 times
Done with:
pa1 = pd1.newObject('PartDesign::Pad', 'pad1')
pa1.Type = u"Length"
pa1.UseCustomVector = True
pa1.Direction = (0.57, 0.57, 0.57)
pa1.Profile = sk1
pa1.Length = 53 * 0.5
seen from Top.
dprojects
Post by dprojects »
onekk wrote: Fri Sep 30, 2022 4:38 pm pa1 = pd1.newObject('PartDesign::Pad', 'pad1')
No, I mean extrude command from face object, not PartDesign Pad command:
shape = Part.makePolygon(verticesArray)
face = Part.Face(shape)
face.extrude(FreeCAD.Vector(0, 0, "18"))
If you create shape, next face and you extrude the face to get solid object in 3D not face at 2D. The face is 2D object. And I want to Pad it but not along axis but from face... above equally... maybe I am looking for face2sketch... or some kind of tutorial about Sketch placement and vertex logic?
or maybe it is possible to use face.extrude but not like this, along axis, but like it is at PartDesign Pad, above from given face?:
face.extrude("face1","18")    <= this syntax exists?
Thanks
Darek
No this is not exist, but you can use the centre of the "destination face" as "destination vector" of extrude.
if you want something different use a Loft provided the face have same edge count.
or ruled surface between the face "sorting edges" to avoid crossing.
Sadly not at my computer now, so no examples.
dprojects
Post by dprojects »
onekk wrote: Fri Sep 30, 2022 6:06 pm No this is not exist
I found it ;-) in the TheMarkster script.
@TheMarkster use the Draft.makeSketch command and the Pad is created at face, automatically. The Draft is great workbench, it always impressed me how good API it has !!! I need to play with it little more and read about this command because the panel is not always created in the right place but maybe I will be able to do it like this ;-)
Thanks
Darek
Re: [solved] Sketch vs Extrude - how sketch is working?
Ah ok.
I use Draft for some functions, and not unusually I steal some code from sources.
It is a good "high level" abstraction from Part.
And is the base of Arch WB one of FC pillars.
TheMarkster code is usually very interesting.
I usually use Part WB so my answers usually don't consider other WB. :)
Thanks for the suggestions.
dprojects
Post by dprojects »
onekk wrote: Fri Sep 30, 2022 7:17 pm I use Draft for some functions, and not unusually I steal some code from sources.
I think Draft is best workbench from API perspective. The Draft.rotate is the only one working function, currently at FreeCAD to rotate things.
but I was happy too soon ;-) I don't know what to say ;-) this is bug at Sketch? https://forum.freecadweb.org/viewtopic.php?f=22&t=72250
Thanks
Darek
