Trying to detect when a Shapebinder is inserted in Body
freedman
Post by freedman »
Lets say a new body is created and then a shapebinder is inserted, I can't find any way to detect the addition.
I have tried these slots but they don't trigger on inserting:
void slotChangedDocument(const App::Document& Obj, const App::Property& Prop);
void slotCreatedObject(const App::DocumentObject& Obj);
void slotBeforeChangeObject(const App::DocumentObject& Obj, const App::Property& Prop);
void slotChangedObject(const App::DocumentObject& Obj, const App::Property& Prop);
I object slots only trigger on feature objects.
Any ideas?
Thanks
openBrain
Re: Trying to detect when a Shapebinder is inserted in Body
Post by openBrain »
I would expect 'slotCreatedObject' to trigger. Maybe an issue in the code.
Just in case, did you also check slots of Gui document observer?
freedman wrote: Thu Sep 29, 2022 2:56 pm Lets say a new body is created and then a shapebinder is inserted, I can't find any way to detect the addition.
What is the order:
  1. The new body is created
  2. A shapebinder is inserted
In other word you want to detect when in an existing Body a Shapebinder is inserted.
I would guess that:
Is the right functions, if ShapeBinder or similar is a Property, it could be maybe a matter of property name.
At least if things works as in a Feature Python Object that is matching the name as string, when experimenting I have mispelled a property name and things were not triggered.
But is only a guess.
freedman
Post by freedman »
Sorry,sorry. I restarted FreeCAD and now it works. Thanks all. I'll try to remember to do that next time.
Edit: slotCreatedObject() does return the shapebinder name.
freedman
Post by freedman »
My goals are to start a post about shapebinders. It seems to me that when a shapebinder is created (in the Active Body), the support object should be hidden and then a quick search thru the Doc and hide any other shapebinders with the same support.
If the shapebinder is hidden then the support object is shown.
Thanks again.
