I have a Face which has four vertex's vxy1 = [v1, v4, v3, v2, v1]
The values of V1 through to V4 are such that the Face is close to coplanar but is not coplanar such that trying to create a Face
produces an error
File "/Users/keithsloan/Library/Application Support/FreeCAD/Mod/GDML/./freecad/gdml/GDMLObjects.py", line 3448, in createGeometry
fxy1 = Part.Face(Part.makePolygon(vxy1))
<class 'Part.OCCError'>: Failed to create face from wire
Is there a good way to adjust values of the vertex such that the face is coplanar and does not produce an error.
Bearing in mind this is just one Face of the object so adjusting it will effect other faces.
coplanar face
Re: coplanar face
I see two possibilities using DatumPlanes:
1) Attach a DatumPlane to three points and project the fourth on the plane
2) Attach a DatumPlane with Inertia2-3 and map all points onto the plane.
Re: coplanar face
You may want to try:keithsloan52 wrote: ↑Tue Sep 27, 2022 11:25 am I have a Face which has four vertex's vxy1 = [v1, v4, v3, v2, v1]
produces an error
>>> help(Part.Vertex.isInside)
Help on method_descriptor:
isInside(...)
Checks whether a point is inside or outside the shape.
isInside(point, tolerance, checkFace) => Boolean
checkFace indicates if the point lying directly on a face is considered to be inside or not
Thanks
Darek
github.com/dprojects
Re: coplanar face
This is the key. You need to think through how you will adjust the vertices of each face so the process will come to an end. You can consider adjusting one vertex at a time so it is coplanar with the other three, or you can make the best-fit plane and adjust all four vertices.keithsloan52 wrote: ↑Tue Sep 27, 2022 11:25 am Bearing in mind this is just one Face of the object so adjusting it will effect other faces.
