Error at the position because of the Rotation centre ?
manos
Post by manos »
OS: Ubuntu 18.04.5 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.29177 (Git) AppImage
  * workfeature-macro
  * Manipulator 1.4.9
  * Help 1.0.3
  * workfeature
I have written this snippet at which I set the Placement.base. vector at 10,20,4 position and the centre at v(0,0,0) . As expected the placement position was at 10,20,4 . Then I changed the centre at 30,30,30 and at my big surprise the new placement position was at 10.52, 19.48, 4 .
It is about 5% error. Any explanation ?
Box1.FCStd
(8.89 KiB) Downloaded 12 times
centre_issue.py
(416 Bytes) Downloaded 12 times
openBrain
Re: Error at the [position because of the Rotation centre ?
Post by openBrain »
Your code says : apply rotation of 1° around Z axis with rotation center at (30,30,30) then place object at (10,20,4).
Anyway, I didn't check the calculation but the result seems correct to me.
manos
Post by manos »
openBrain wrote: Mon Sep 26, 2022 11:41 am Your code says : apply rotation of 1° around Z axis with rotation center at (30,30,30) then place object at (10,20,4).
The correct result is : " Global Placement after recomp= Placement [Pos=(10.0,20.0,4), Yaw-Pitch-Roll=(1,0,0)]. "
But I had this one : " Global Placement after recomp= Placement [Pos=(10.5281, 19.481, 4), Yaw-Pitch-Roll=(1,0,0)] "
Which one did you have ?
Thanks for help
openBrain
Post by openBrain »
manos wrote: Mon Sep 26, 2022 12:25 pm The correct result is : " Global Placement after recomp= Placement [Pos=(10.0,20.0,4), Yaw-Pitch-Roll=(1,0,0)]. "
No it's not because you offset the rotation center.
If you want this :
newplace=FreeCAD.Placement(pos,rot) # remove "centre"
The question is : why are you offsetting the rotation center ?
manos
Post by manos »
openBrain wrote: Mon Sep 26, 2022 12:28 pm The correct result is : " Global Placement after recomp= Placement [Pos=(10.0,20.0,4), Yaw-Pitch-Roll=(1,0,0)]. "
No to No: The deviation is not directly proportional to the offset . And the rotation center what has to do with the position of the prism which is symmetrical ? Maybe it is a bug.
I try to use an edge of the prism as axis of rotation.
Thanks anyway openBrain.
openBrain
Post by openBrain »
manos wrote: Mon Sep 26, 2022 12:52 pm No to No: The deviation is not directly proportional to the offset .
Sure. This is rotations, so basically trigonometrical things. And trigonometric functions aren't linear.
I don't know how to better explain. Take your file (from the OP) and check this (this is same rotation as you do, but without translating the base)
>>> App.ActiveDocument.Body.Placement = App.Placement(App.Vector(0,0,0), App.Rotation(App.Vector(0,0,1),1), App.Vector(30,30,30))
Placement [Pos=(0.528141,-0.519003,0), Yaw-Pitch-Roll=(1,0,0)]
And bing. You see the offset that the rotation creates on the base. It perfectly matches what you see.
Maybe you should tell what you are (functionally) trying to achieve.
manos
Re: Error at the position because of the Rotation centre ?
Post by manos »
openBrain wrote: Mon Sep 26, 2022 2:07 pm
Thanks open Brain I will try all that. By the way what does it mean "Take your file (from the OP) " ?
openBrain
Post by openBrain »
It means I did it using the file you posted in the OP.
manos
Post by manos »
openBrain wrote: Tue Sep 27, 2022 3:34 am It means I did it using the file you posted in the OP.
Yes but what is the OP anyway ?
freedman
Post by freedman »
OP = Original post = first post = starting post
manos, about placements: keep track of the wording attachment offset and placement and how the placement is changed. We don't want to guess how a placement got modified.
Thanks
