How to add offset at Placement.Rotation.Axis ?
manos
Post by manos »
#print(' Global Placement before',obj.getGlobalPlacement())
sel=FreeCADGui.Selection.getSelectionEx()[0]
obj=sel.Object
v1 = App.Vector(1,1,1)
v2=App.Vector(6,7,9)
obj.Placement.Base=v2
obj.Placement.Rotation.Axis=v1
obj.Placement.Rotation.Angle=0.3
#obj.Placement.Rotation.Center=(1,0,0)
print(' Global Placement after',obj.getGlobalPlacement())
print('---------End---------')
I need to add an offset to obj.Placement.Rotation.Axis . At Sandbox:@Edwilliams16 there is such example, but uses App. (https://wiki.freecadweb.org/Sandbox:Edw ... #Rotations)
I prefer -if possible- to use the selected object as above.
Any help welcomed.
Re: How to add offset at Placement.Rotation.Axis ?
manos wrote: Sun Sep 25, 2022 8:59 am ...
Any help welcomed.
from FreeCAD import Rotation
rot = Rotation(v2, 30)
rotVec = rot.multVec(v1)
You are referring to this code.
In this case what is the result of doing something similar to:
rot = obj.Placement.Rotation
The example is using a Rotation, you inted to use an "existing" rotation, and multiply it by a "translation vector".
usually when having problem I use the Matrix form that has the ability to be additive:
m = obj.Placement.Matrix
m.move()
m.rotateX()
m.rotateY()
obj.Placement.Matrix = m
help(FreeCAD.Matrix)
will give you an idea about the transformations that you could apply.
Hope it helps.
manos
Post by manos »
onekk wrote: Sun Sep 25, 2022 9:08 am
Thanks onekk I will try it.
manos wrote: Sun Sep 25, 2022 9:26 am Thanks onekk I will try it.
I've forgotten to say that Matrix is however "stored" as a quaternion internally.
In other word the transformation is applied, and some calculations could be done using Matrix, but the result is stored in a quaternion and "translated" in a Matrix representation so, if there are "equivalent" transformation probably the process of translate, operate on the matrix, save as quaternion and translate the quaternion in matrix, could not permit to as example make some test between the Matrix.
Same as when you specify rotation of more than 360 degree and then when retrieving the Placement you have them "normalised" in the range of 0 - 360.
There are some forum post that mark this as a bug, but this is the way FC and probably OCCT store things, there are around some post that discuss this thing, but sadly I have not noted them. So take it as a "to be verified" answer.
manos
Post by manos »
I suppose v2 is the obj(.Placement.)Rotation.Axis = The direction of the Axis
30 is the obj(.Placement.)Rotation.Angle
v1 is the offset of the obj(.Placement.)Rotation.Axis
Probably you mean: In this case That is the result of doing something similar to:
Do you agree to those notes Carlo ? Thanks for your time.
manos wrote: Sun Sep 25, 2022 10:33 am
Rotation is composed in many ways, probably this is the form:
Rotation(Axis, angle)
help(FreeCAD.Rotation)
Should do some hints.
you could use many ways when specificing rotations, as it is very flexible but complex.
Probably the most difficult part of Placement
Now I'm not at computer so I'm using my "impaired" memory.
manos
Post by manos »
onekk wrote: Sun Sep 25, 2022 11:00 am
OK Carlo thanks a lot.
