Other form of GlobalPlacement Rotation
manos
Post by manos »
Hi
The rotation of GlobalPlacement can be presented in many forms: The getGlobalPlacement uses the form :Euler angles and Angle. But another form would be very usefull too, like : Vector (rotation axis) and float (rotation angle) . Is there any way to get Global Placement Rotation in this or another way ?
Any help is welcomed.
openBrain
Re: Other form of GlobalPlacement Rotation
Post by openBrain »
:? '.Angle' and '.Axis' are exactly this.
'.Angle' isn't linked to Euler angles, which are standalone.
manos
Post by manos »
openBrain wrote: Fri Sep 23, 2022 6:37 pm :? '.Angle' and '.Axis' are exactly this.
Unfortunately both obj.Placement.Rotation.Axis and obj.Placement.Rotation.Angle refer to the Local Coordinate System not to the Global.
Thanks anyway.
openBrain
Post by openBrain »
obj.getGlobalPlacement().Rotation.Axis
obj.getGlobalPlacement().Rotation.Angle
A placement is a placement, whatever the way you got it.
manos
Post by manos »
openBrain wrote: Fri Sep 23, 2022 7:16 pm
I hadn't tried with parenthesis. I am a stupid.
Thanks a lot openBrain.
