Wondering if anyboy else would be interested in improving the code.
The code is in classCurveFitFeature in toSCommands.py and it uses a python library geomdl
Attached is a test file
- Throttle_lock - is an import STL Mesh
- Throttle_lock_cs is a cross section of the Mesh using the Mesh Workbench
- Sketch is a Sketch produced by the toSketch icon/function of the workbench
- Fitted_Sketch is the result of trying to curve fit the sketch i.e. Select Sketch and click on ToCurveFit
