Sections of a BSPlineCurve
Probably already asked, but now I'm lost:
There is a way to section a BSPlineCurve, using some lines?
I have put together this example code.
20220813-bspline_sections.py
(18.1 KiB) Downloaded 13 times
While I have no problems in obtaining two sections, or better three, section1, section2 and section4:
With section3 I have some problems:
    #sect3 = base_spline.trim(val2, val3)
    #Part.show(sect3.toShape(), "section3")
I obtain this error.
line 84 in build_guide_curves
<class 'Part.OCCError'>: Geom_BSplineCurve::Segment
calculate values for val1, val2, val3 and val4 are:
0.6347036128356511 0.9011348830671121 0.1896785450093899 0.33167715079093957
I could guess that the problem is passing val2 and val3 to obtain a segment that cross the "start point" of the curve.
I could make some if conditions to generalize more the method, but the problem is to obtain section to pass to a gordon surface creations where I have to use the spline sections as "guide_curves"
# InterpolateCurveNetwork(profile_curves, guide_curves, tol3, tol2)
gordon = InterpolateCurveNetwork([bs0,bs1,bs2],[bs3,bs4,bs5],0.1,0.001)
Hope of having explained decently my problem.
edwilliams16
Re: Sections of a BSPlineCurve
Post by edwilliams16 »
Shouldn't your BSpline be a periodic one?
edwilliams16 wrote: Sat Aug 13, 2022 7:55 pm Shouldn't your BSpline be a periodic one?
If you intend "closed" BSpline, yes I've forgotten the correct term sorry.
EDIT:
I've checked the code and I've seen that probably the BSPline is not periodic at all,
in the original code is created with:
newpoints = []
for point in cm_pts:
    newpoints.append(Vector(*point))
base_spline = Part.BSplineCurve()
base_spline.buildFromPoles(newpoints)
The test code above is created using the methods supplied from Curves WB to generate Python Code starting from the original BSPline:
periodic0 = False
degree0 = 3
rational0 = False
bs0 = Part.BSplineCurve()
bs0.buildFromPolesMultsKnots(poles0, mults0, knots0, periodic0, degree0, weights0, rational0)
So now the question is how to close a BSpline?
I've already had an answer some time ago,
These forum posts explain the mechanics:
https://forum.freecadweb.org/viewtopic. ... 21#p615621
https://forum.freecadweb.org/viewtopic. ... 21#p561221
But I'm missing the passages to pass from the open BSPline to the closed BSpline using the original points.
Probably there are some passages to create the missing (in my case) mults0 and knots0 as I have only some "interpolated points that populate the poles of the first piece of code:
or point in cm_pts:
END EDIT:
edwilliams16
I made your bspline periodic with bspline.setPeriodic(). Its parameter range is 0 <= u < 1 Being periodic makes u + n (n integer) the same point for every n.
Your u parameters go like 0 < val3 < val4 <val1 < val2 < 1
spline.trim(val3, val4) cuts out the segment between 3 and 4 as expected. However the trim function doesn't handle spline.trim(val2, val3) correctly as it doesn't realize the curve is periodic - spline.trim(val2, val3 + 1) fixes this, cutting the section out between 2 and 3 in the direction of increasing u parameter.
Note that if you want the (shorter) section between 1 and 4, starting at 1, you need spline.trim(val4, val1).reverse()
import FreeCAD
from FreeCAD import Vector
import Part
DOC = FreeCAD.ActiveDocument
if DOC is None:
    FreeCAD.newDocument("test_bspline")
DEBUG = False
if DEBUG:
    import sys
    freecadpython = sys.executable.replace('freecad', 'python')
    App.Console.PrintMessage('Using ' + freecadpython +'\n')
    try:
        import debugpy
    except ModuleNotFoundError:
        App.Console.PrintMessage('Install debugpy by: ' + freecadpython + ' -m pip install --upgrade debugpy\n')
    #see https://github.com/microsoft/debugpy/issues/262
    debugpy.configure(python=freecadpython)
    if not debugpy.is_client_connected():
        debugpy.listen(5678)
    App.Console.PrintMessage("Waiting for debugger attach\n")
    debugpy.wait_for_client()
    debugpy.breakpoint()
poles0 = [Vector (-56.64199999999988, -108.52651511673002, 0.0), Vector (-47.7919859277423, -105.28034589991853, 0.0), Vector (-38.888377225634116, -102.18420059598452, 0.0), Vector (-29.933716868418003, -99.23896350022585, 0.0), Vector (-20.930562411786696, -96.44547580679159, 0.0), Vector (-11.881485261914264, -93.8045353684272, 0.0), Vector (-2.7890699410333184, -91.316896468599, 0.0), Vector (6.344086650735676, -88.98326960606119, 0.0), Vector (15.51537597708844, -86.80432129192957, 0.0), Vector (24.722178610566417, -84.7806738593182, 0.0), Vector (33.961864980694756, -82.91290528559352, 0.0), Vector (43.2317961250195, -81.20154902729735, 0.0), Vector (52.529324442825086, -79.64709386778577, 0.0), Vector (61.851794451321, -78.2499837776262, 0.0), Vector (71.19654354407778, -77.0106177877949, 0.0), Vector (80.56090275149953, -75.92934987570902, 0.0), Vector (89.94219750311183, -75.00648886412569, 0.0), Vector (99.33774839145133, -74.24229833293975, 0.0), Vector (108.74487193733486, -73.63699654390155, 0.0), Vector (118.16088135629343, -73.19075637827893, 0.0), Vector (127.58308732594845, -72.90370528748042, 0.0), Vector (137.00879875411403, -72.77592525665375, 0.0), Vector (146.43532354740452, -72.8074527812696, 0.0), Vector (155.85996938012778, -72.99827885669845, 0.0), Vector (165.28004446324445, -73.3483489807819, 0.0), Vector (174.69285831317472, -73.85756316939978, 0.0), Vector (184.09572252023216, -74.52577598502626, 0.0), Vector (193.4859515164646, -75.35279657826868, 0.0), Vector (202.86086334268361, -76.33838874237631, 0.0), Vector (212.21778041446356, -77.48227098070413, 0.0), Vector (221.5540302868914, -78.7841165871107, 0.0), Vector (230.86694641784777, -80.24355373927051, 0.0), Vector (240.15386892960242, -81.86016560486962, 0.0), Vector (248.9731868856047, -85.14998874821593, 0.0), Vector (258.0410087091944, -87.71242906404285, 0.0), Vector (267.315911594915, -89.37606047063355, 0.0), Vector (276.7090296974566, -90.12494317723734, 0.0), Vector (286.13036451326974, -89.95190189635201, 0.0), Vector (295.4896471853463, -88.85859459247474, 0.0), Vector (304.6972033983433, -86.85549659660789, 0.0), Vector (313.6648125772109, -83.96180023872353, 0.0), Vector (322.30655315706497, -80.20523095984058, 0.0), Vector (330.53962582549855, -75.62178166560417, 0.0), Vector (338.28514684958265, -70.25536786661178, 0.0), Vector (345.46890388643305, -64.15740690969784, 0.0), Vector (352.022067035678, -57.38632533169853, 0.0), Vector (357.88184832100256, -50.00699905589909, 0.0), Vector (362.99210328206374, -42.090131794823264, 0.0), Vector (367.30386891272974, -33.71157761508846, 0.0), Vector (370.7758327914832, -24.951614155051914, 0.0), Vector (373.37472890909754, -15.894173458784934, 0.0), Vector (375.07565640103434, -6.626037796003672, 0.0), Vector (375.8623181306826, 2.7639918269342156, 0.0), Vector (375.7271768374974, 12.185946498201766, 0.0), Vector (374.67152735393176, 21.549551421755083, 0.0), Vector (372.70548419922807, 30.765090869361334, 0.0), Vector (369.8478846689366, 39.744267776017224, 0.0), Vector (366.1261083486925, 48.401049742695974, 0.0), Vector (361.5758147815475, 56.65249334059703, 0.0), Vector (356.24060180235057, 64.41953881897251, 0.0), Vector (350.1715878127872, 71.62776760217787, 0.0), Vector (343.4269219994341, 78.2081153181218, 0.0), Vector (336.07122718758876, 84.09753352636085, 0.0), Vector (328.1749806690735, 89.23959380560476, 0.0), Vector (319.81383893649934, 93.58502841267831, 0.0), Vector (311.06791279393406, 97.09220233270787, 0.0), Vector (302.0209997893683, 99.72751219766985, 0.0), Vector (292.75978132329845, 101.4657082511312, 0.0), Vector (283.372992126182, 102.29013627433534, 0.0), Vector (273.9505700622782, 102.19289715566003, 0.0), Vector (264.5827944058706, 101.17492257456162, 0.0), Vector (255.35942084633317, 99.24596607485276, 0.0), Vector (246.36882150983, 96.42450961284332, 0.0), Vector (237.5202028867966, 93.17832912815834, 0.0), Vector (228.54791246815876, 90.28841710413747, 0.0), Vector (219.48088552023586, 87.71109112774258, 0.0), Vector (210.33000867385084, 85.44944575208109, 0.0), Vector (201.1062692370266, 83.50619649773063, 0.0), Vector (191.8207420027061, 81.88367659225872, 0.0), Vector (182.4845759514291, 80.58383416875398, 0.0), Vector (173.108980864934, 79.60822992673508, 0.0), Vector (163.70521386675577, 78.95803525824402, 0.0), Vector (154.28456590598313, 78.63403084137514, 0.0), Vector (144.85834820040026, 78.63660570292757, 0.0), Vector (135.43787865529208, 78.96575675130725, 0.0), Vector (126.03446827422198, 79.62108878023884, 0.0), Vector (116.65940757809443, 80.60181494328333, 0.0), Vector (107.32395304881051, 81.906757698592, 0.0), Vector (98.0393136137959, 83.53435022276142, 0.0), Vector (88.84751156665534, 85.61398007591114, 0.0), Vector (79.87942134582622, 88.50760264707017, 0.0), Vector (71.21543499690037, 92.21368337188969, 0.0), Vector (62.928978829625414, 96.7008136331015, 0.0), Vector (55.09027962792554, 101.93096550647208, 0.0), Vector (47.765769485807155, 107.85981404318282, 0.0), Vector (40.705096851224106, 114.10246454243367, 0.0), Vector (33.0891850669656, 119.65062891067672, 0.0), Vector (24.944104225869552, 124.38791698030678, 0.0), Vector (16.35586442629087, 128.26430412655296, 0.0), Vector (7.415155418800371, 131.23885663172535, 0.0), Vector (-1.7836110558102618, 133.28016393544735, 0.0), Vector (-11.143298231846394, 134.36667032263264, 0.0), Vector (-20.565070059637296, 134.48690254666175, 0.0), Vector (-29.949434890493947, 133.6395909841122, 0.0), Vector (-39.19729608463493, 131.8336830416769, 0.0), Vector (-48.270454181715664, 129.2804599061286, 0.0), Vector (-57.5089533295608, 127.42972731993632, 0.0), Vector (-66.89367294037379, 126.59180403182881, 0.0), Vector (-76.31391379172884, 126.7765739232957, 0.0), Vector (-85.6585576637372, 127.98185750638619, 0.0), Vector (-94.8173780548756, 130.19343763226863, 0.0), Vector (-103.6823403793832, 133.38522719227907, 0.0), Vector (-112.17085347036885, 137.4780138798098, 0.0), Vector (-120.65208512897192, 141.5914933122695, 0.0), Vector (-129.28199710883348, 145.3831450246506, 0.0), Vector (-138.0483826169826, 148.8476058211778, 0.0), Vector (-146.93884182208242, 151.97997530937928, 0.0), Vector (-155.94079939367936, 154.77582283156812, 0.0), Vector (-165.04152228969062, 157.23119373189596, 0.0), Vector (-174.2281377669716, 159.3426149501141, 0.0), Vector (-183.4876515894865, 161.10709993412962, 0.0), Vector (-192.80696640832755, 162.52215286440807, 0.0), Vector (-202.17290028758512, 163.5857721842472, 0.0), Vector (-211.57220534986374, 164.29645343092852, 0.0), Vector (-220.9915865150705, 164.65319136374202, 0.0), Vector (-230.4177203059712, 164.65548138587363, 0.0), Vector (-239.8372734695545, 164.30331626568707, 0.0), Vector (-249.22853449018976, 163.5020019746425, 0.0), Vector (-258.5580520344799, 162.1611102782264, 0.0), Vector (-267.79485060824834, 160.28509315187446, 0.0), Vector (-276.90826255916727, 157.8801792732538, 0.0), Vector (-285.8680298982814, 154.9543533420542, 0.0), Vector (-294.64440476138225, 151.51732956950514, 0.0), Vector (-303.2082481766877, 147.58051942563668, 0.0), Vector (-311.5311268109003, 143.15699375136927, 0.0), Vector (-319.58540737243305, 138.2614393612261, 0.0), Vector (-327.3443483583684, 132.91011028075388, 0.0), Vector (-334.7821888405356, 127.1207737805518, 0.0), Vector (-341.8742339959225, 120.91265138608436, 0.0), Vector (-348.59693709744846, 114.3063550591347, 0.0), Vector (-354.92797769287307, 107.32381876278644, 0.0), Vector (-360.84633571227687, 99.98822563714938, 0.0), Vector (-366.33236125806394, 92.32393102761692, 0.0), Vector (-371.3678398457723, 84.35638162121437, 0.0), Vector (-375.9360528790835, 76.11203095951754, 0.0), Vector (-380.0218331582426, 67.61825160865317, 0.0), Vector (-383.6116152375935, 58.90324427799037, 0.0), Vector (-386.6934804650339, 49.99594418926365, 0.0), Vector (-389.2571965538506, 40.925925006997495, 0.0), Vector (-391.29425155555316, 31.72330064919743, 0.0), Vector (-392.79788212090693, 22.418625304314663, 0.0), Vector (-393.7630959553371, 13.042791986440472, 0.0), Vector (-394.18668839414755, 3.6269299655461933, 0.0), Vector (-394.0672530425209, -5.797698586684166, 0.0), Vector (-393.4051864449753, -15.199802392277414, 0.0), Vector (-392.20268676877276, -24.54816495903038, 0.0), Vector (-390.46374650565167, -33.81174822427022, 0.0), Vector (-388.19413921611374, -42.95979560619893, 0.0), Vector (-385.4014003602775, -51.96193412067626, 0.0), Vector (-382.0948022789424, -60.78827522439799, 0.0), Vector (-378.28532340793083, -69.40951404965112, 0.0), Vector (-373.9856118279206, -77.7970267011743, 0.0), Vector (-369.20994327078904, -85.92296529207947, 0.0), Vector (-363.97417372189454, -93.76035040330142, 0.0), Vector (-358.295686775662, -101.28316065959544, 0.0), Vector (-352.1933359192628, -108.46641912467514, 0.0), Vector (-345.6873819360138, -115.28627622864603, 0.0), Vector (-338.7994256363284, -121.72008895240168, 0.0), Vector (-331.55233613956204, -127.74649600607765, 0.0), Vector (-323.9701749448695, -133.34548875195904, 0.0), Vector (-316.0781160431691, -138.4984776363663, 0.0), Vector (-307.90236233545636, -143.18835390995378, 0.0), Vector (-299.47005863497196, -147.39954643150082, 0.0), Vector (-290.80920154206865, -151.1180733665976, 0.0), Vector (-281.9485464910087, -154.33158860957718, 0.0), Vector (-272.9175122773122, -157.0294227745658, 0.0), Vector (-263.74608338263846, -159.2026186195549, 0.0), Vector (-254.46471042149864, -160.84396078588082, 0.0), Vector (-245.10420904033384, -161.94799975437246, 0.0), Vector (-235.69565760462729, -162.51106993862865, 0.0), Vector (-226.27029401374764, -162.53130185535292, 0.0), Vector (-216.85941198611442, -162.00862833133766, 0.0), Vector (-207.49425715903539, -160.94478472649007, 0.0), Vector (-198.1985167781159, -159.38308570070905, 0.0), Vector (-188.9523935803173, -157.54821083259674, 0.0), Vector (-179.75662582212215, -155.47567245952763, 0.0), Vector (-170.6173213759986, -153.16684717129846, 0.0), Vector (-161.5405506112146, -150.62326850059287, 0.0), Vector (-152.5323423618721, -147.84662590440263, 0.0), Vector (-143.59867992252498, -144.83876364188166, 0.0), Vector (-134.7454970740472, -141.60167954938044, 0.0), Vector (-125.97867414238848, -138.13752371347425, 0.0), Vector (-117.30403409283193, -134.44859704286455, 0.0), Vector (-108.72727723911248, -130.53748016363102, 0.0), Vector (-100.17069133143457, -126.58197619956104, 0.0), Vector (-91.56235700959934, -122.74039394627562, 0.0), Vector (-82.90379093769877, -119.01341023504551, 0.0), Vector (-74.19651862993283, -115.40168170653487, 0.0), Vector (-65.44207418183686, -111.9058446951102, 0.0), Vector (-56.641999999999854, -108.52651511673002, 0.0)]
weights0 = [1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0, 1.0]
knots0 = [0.0, 0.005076142131979695, 0.01015228426395939, 0.015228426395939087, 0.02030456852791878, 0.025380710659898477, 0.030456852791878174, 0.03553299492385787, 0.04060913705583756, 0.04568527918781726, 0.050761421319796954, 0.05583756345177665, 0.06091370558375635, 0.06598984771573604, 0.07106598984771574, 0.07614213197969544, 0.08121827411167512, 0.08629441624365482, 0.09137055837563451, 0.09644670050761421, 0.10152284263959391, 0.1065989847715736, 0.1116751269035533, 0.116751269035533, 0.1218274111675127, 0.12690355329949238, 0.1319796954314721, 0.13705583756345177, 0.14213197969543148, 0.14720812182741116, 0.15228426395939088, 0.15736040609137056, 0.16243654822335024, 0.16751269035532995, 0.17258883248730963, 0.17766497461928935, 0.18274111675126903, 0.18781725888324874, 0.19289340101522842, 0.19796954314720813, 0.20304568527918782, 0.20812182741116753, 0.2131979695431472, 0.2182741116751269, 0.2233502538071066, 0.22842639593908629, 0.233502538071066, 0.23857868020304568, 0.2436548223350254, 0.24873096446700507, 0.25380710659898476, 0.25888324873096447, 0.2639593908629442, 0.26903553299492383, 0.27411167512690354, 0.27918781725888325, 0.28426395939086296, 0.2893401015228426, 0.29441624365482233, 0.29949238578680204, 0.30456852791878175, 0.3096446700507614, 0.3147208121827411, 0.3197969543147208, 0.3248730964467005, 0.3299492385786802, 0.3350253807106599, 0.3401015228426396, 0.34517766497461927, 0.350253807106599, 0.3553299492385787, 0.3604060913705584, 0.36548223350253806, 0.37055837563451777, 0.3756345177664975, 0.38071065989847713, 0.38578680203045684, 0.39086294416243655, 0.39593908629441626, 0.4010152284263959, 0.40609137055837563, 0.41116751269035534, 0.41624365482233505, 0.4213197969543147, 0.4263959390862944, 0.43147208121827413, 0.4365482233502538, 0.4416243654822335, 0.4467005076142132, 0.4517766497461929, 0.45685279187817257, 0.4619289340101523, 0.467005076142132, 0.4720812182741117, 0.47715736040609136, 0.48223350253807107, 0.4873096446700508, 0.49238578680203043, 0.49746192893401014, 0.5025380710659898, 0.5076142131979695, 0.5126903553299492, 0.5177664974619289, 0.5228426395939086, 0.5279187817258884, 0.5329949238578681, 0.5380710659898477, 0.5431472081218274, 0.5482233502538071, 0.5532994923857868, 0.5583756345177665, 0.5634517766497462, 0.5685279187817259, 0.5736040609137056, 0.5786802030456852, 0.583756345177665, 0.5888324873096447, 0.5939086294416244, 0.5989847715736041, 0.6040609137055838, 0.6091370558375635, 0.6142131979695431, 0.6192893401015228, 0.6243654822335025, 0.6294416243654822, 0.6345177664974619, 0.6395939086294417, 0.6446700507614214, 0.649746192893401, 0.6548223350253807, 0.6598984771573604, 0.6649746192893401, 0.6700507614213198, 0.6751269035532995, 0.6802030456852792, 0.6852791878172588, 0.6903553299492385, 0.6954314720812182, 0.700507614213198, 0.7055837563451777, 0.7106598984771574, 0.7157360406091371, 0.7208121827411168, 0.7258883248730964, 0.7309644670050761, 0.7360406091370558, 0.7411167512690355, 0.7461928934010152, 0.751269035532995, 0.7563451776649747, 0.7614213197969543, 0.766497461928934, 0.7715736040609137, 0.7766497461928934, 0.7817258883248731, 0.7868020304568528, 0.7918781725888325, 0.7969543147208121, 0.8020304568527918, 0.8071065989847716, 0.8121827411167513, 0.817258883248731, 0.8223350253807107, 0.8274111675126904, 0.8324873096446701, 0.8375634517766497, 0.8426395939086294, 0.8477157360406091, 0.8527918781725888, 0.8578680203045685, 0.8629441624365483, 0.868020304568528, 0.8730964467005076, 0.8781725888324873, 0.883248730964467, 0.8883248730964467, 0.8934010152284264, 0.8984771573604061, 0.9035532994923858, 0.9086294416243654, 0.9137055837563451, 0.9187817258883249, 0.9238578680203046, 0.9289340101522843, 0.934010152284264, 0.9390862944162437, 0.9441624365482234, 0.949238578680203, 0.9543147208121827, 0.9593908629441624, 0.9644670050761421, 0.9695431472081218, 0.9746192893401016, 0.9796954314720813, 0.9847715736040609, 0.9898477157360406, 0.9949238578680203, 1.0]
mults0 = [4, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 4]
periodic0 = False
degree0 = 3
rational0 = False
bs0.setPeriodic()
def build_guide_curves(base_spline, fact1, fact2):
    """Build guide curves for gordon surface."""
    sp_dims = base_spline.toShape().BoundBox
    xmax = sp_dims.XMax
    xmin = sp_dims.XMin
    ymin = sp_dims.YMin
    ymax = sp_dims.YMax
    dim_x = sp_dims.XLength
    int_incr = 1.0
    tol1 = 0.01
    # Create  lines to find intersection points:
    lines = []
    idx = 0
    xpos = xmin
    xpos_std_min = xmin + dim_x * fact1
    xpos_std_max = xmin + dim_x * fact2
    Part.show(base_spline.toShape(), "base_spline")
    line1 = Part.LineSegment(
        Vector(xpos_std_min, ymin - int_incr, 0),
        Vector(xpos_std_min, ymax + int_incr, 0))
    Part.show(line1.toShape(), "line1")
    pts1 = base_spline.intersect(line1, tol1)
    print(pts1, "points1")
    val1 = base_spline.parameter(Vector(pts1[0].X, pts1[0].Y, pts1[0].Z))
    val2 = base_spline.parameter(Vector(pts1[1].X, pts1[1].Y, pts1[1].Z))
    sect1 = base_spline.trim(val1, val2)
    Part.show(sect1.toShape(), "section1-2")
    line2 = Part.LineSegment(
        Vector(xpos_std_max, ymin - int_incr, 0),
        Vector(xpos_std_max, ymax + int_incr, 0))
    Part.show(line2.toShape(), "line2")
    pts2 =  base_spline.intersect(line2, tol1)
    print(pts2, "points2")
    val3 = base_spline.parameter(Vector(pts2[0].X, pts2[0].Y, pts2[0].Z))
    val4 = base_spline.parameter(Vector(pts2[1].X, pts2[1].Y, pts2[1].Z))
    sect2 = base_spline.trim(val3, val4)
    Part.show(sect2.toShape(), "section3-4")
    print(val1, val2, val3, val4)
    sect3 = base_spline.trim(val2, val3 + 1)
    Part.show(sect3.toShape(), "section2-3")
    sect4 = base_spline.trim(val4, val1)
    sect4.reverse()
    Part.show(sect4.toShape(), "section1-4")
    for i, val in enumerate([val1,val2,val3,val4]):
        Part.show(Part.Vertex(base_spline.value(val)), 'val'+str(i + 1))
build_guide_curves(bs0, 0.2, 0.9)
DOC.recompute()
EDIT corrected typos
Thanks @edwilliams16, I will study tomorrow the code (now I'm on mobile).
Many thanks again.
