Does wire.discretize(Number=nb) preserves the shape of curve?
stefankorisnik3
Post by stefankorisnik3 »
Can you let me know if the function
guaranty preserving the shape of the wire (closed curve) with increasing the number of vertexes?
More so does and if the
wire.discretize
choose in every iteration the longest edge and half it?
Roy_043
Re: Does wire.discretize(Number=nb) preserves the shape of curve?
Post by Roy_043 »
Create a Draft_Rectangle and then run this code:
doc = App.ActiveDocument
obj = doc.getObject("Rectangle")
wire = obj.Shape.Wires[0]
pts = wire.discretize(30)
import Draft
Draft.make_wire(pts)
